Good Quartersawing vid
Started by JohnM, December 18, 2013, 09:44:06 PM
JohnM
Maybe you guys have seen this but thought it was worth posting.  As a swing saw owner it doesn't really apply as much to me but still learned some stuff. :)
http://www.youtube.com/watch?v=VvUPJPFg4wM
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
redbeard
Very good presentation, one of my favorite book marks. This is something to show those customers that ask for 50/50 qrt sawing there logs. I show them which boards Iam keeping and then offer there boards. Or they can keep them all for the bf cutting fee. They usually come up with the cash. :laugh:
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
drobertson
thanks johnm, I have seen a few vids, but not this one, pretty good illustration, looks like allot of work,
david
Chuck White
Excellent video, shows how to get the most out of the log!
Only thing, this is where I would switch to hourly rate!
ladylake
Way too much work with that method.   Steve
dboyt
There are other ways of getting that same cut pattern without flipping the board end-for-end.  The easiest I have found involves cutting the log into quarters, then cutting off the bottom, using the sawmill like a band resaw.  After each cut, rotate the log 90 degrees, and make the next cut off the bottom.  This always keeps a flat side down for stability and parallel cuts.  The down side is that you have to raise the saw above the cant each time to return it.  This might not work on all sawmills, but the Norwood lets me cut down to 1-1/8 thick for a bottom cut and the adjustable clamps and log stops adapt to this kind of cutting.
redbeard
Another way is to make a cant. Centering the pith then cut your 4 qrt. Then saw from top down flipping the qrt. (Not end for end) Until it gets 2x4 size.
Tom L
I've been getting in the habit of cutting a 4 x 4 out of the center of the log and quarter sawing the outside parts
it seems when I leave the center pith on the quarter sawn boards that they will dry with a sweep to them.
by not quartering the center I have had better luck air drying quarter sawn lumber.
bedway
Great post JohnM. Never actually quarter sawing any oak myself i always wondered about the hassel of moving the quarters end for end.
Your process dboyt seems even an old fart like me might be able to do. ;D
schmism
it would seem that if you used the bottom half type.  sawed into 8ths then put several 8ths on the mill at a time and just sawed down to the deck would be faster with less log manupulations
039 Stihl 010AV  NH TC33D FEL, with toys
AnthonyW
It looks like having two sets of back stops (back stops and front stops?) would avoid having to rotate the log end for end. With the two sets, make the first pass with the log against the back stop, then roll the log and slide it to hold against the front stops. The roll it again and slide it against the backstops for the next cut.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
bedway
Quote from: schmism on December 19, 2013, 11:19:39 AM
1/2s, 1/4s, 1/8s, That one lost me :o
Possibly, but then you have to clamp the log @ 45°, and edge both sides of each board. Either way, Q-sawing on a band mill does take more messing about, and usually has a slightly lower yield.
The alternating pattern maybe creates less waste?
AnthonyW
Though I have not quartersawn anything, so I cannot speak from personal experience. From the photos, it seems like there would be less waste quartersawing. Each quartersawn board could be edged to trim off just the bark. Opposed to generating those large slabs with all that meat (wood) attached. BUT also quartersawn does not generate boards that are as wide and would take more time.
GDinMaine
Quote from: dboyt on December 19, 2013, 08:30:30 AM
I have quarter sawn birch and poplar logs in the fashion described by dboyt.  I did not switch thecants end-to-end even then it took a long time.  The customer was a carpenter who knew exactly what he was looking for and got the expected result.  He also knew that the process takes a long time and didn't mind paying for it.  He got exactly what he wanted and was happy.
It's the going that counts not the distance!
WM LT-40HD-D42
drobertson
Quote from: AnthonyW on December 19, 2013, 11:25:26 AM
This is a pretty good idea, not just for strictly q-sawing, I've seen the need for reversing the clamp direction arise a few times,  maybe a small pair with adjustable heights, it wouldn't take a real beefy one, just one to stabilize for a few cuts.  david
OH Boy
Quote from: redbeard on December 19, 2013, 08:45:14 AM
If this will work it seems like the simplest way, and cutting off the top sounds great. my little portable saw rolls on wheels so you always want to take off the top. I'm going to give this a shot just to try quartersawing something.
qbilder
Quote from: Ianab on December 19, 2013, 02:16:19 PM
It does create more waste. It's easier & faster, though. Leaves a 45* angle on the straight edge of the board, and bark on the other edge. The top method at least gives one square straight edge.
God bless our troops
Qweaver
look at the drawing that I recently post on my "Quarter sawing on the WPF.  I'm finding QS is very easy on the swinger.  Very little loss also.
Dave Shepard
If I'm quartersawing, I usually have a big log. I will make a large cant then cut it into quarters and push three of them onto the loading arms. I put a quarter on the mill with the pith at one of the top corners. I take a board or two then flip the pith over to the other top corner. I saw until the figure runs out then just saw to the bed.
QuoteI saw until the figure runs out then
The figure??  ...  meaning the rays?
Dave Shepard
Yes. I was thinking about the sycamore, which was the last quarter sawing I did. My quarters were pretty waney, I just squared up the cant enough to make sure the quarters would sit on the mill. Once you get down to about a 6"x6" cant, you are pretty much done making decent boards anyway, considering the wane.
schmism
Quote from: bedway on December 19, 2013, 12:33:15 PM
if you saw the quarters,  then set the quarters on a 45 jig (or something)  then sawed the green line  you split the log into 8ths.  then put 2 8ths (or more) "green line side" down and saw to the deck.
Sixacresand
What few I have ever done on the LT10 was like this.  Flipping ene to end would definitely be too much work.
