new log trailer
Started by mrfu, November 11, 2016, 06:56:13 PM
mrfu
Hi All
Long time lurker but have found a wealth of information on this site.
Just finished a log trailer for use behind my tractor. 3rd time out I accidentally put all the weight of the loader on it and broke a weld, so I reinforced where the axle cross piece meet the main frame and all is well, kinda thought it was a weak design but I was mostly going of pictures from the internet for my design.
thanks for looking
larrydown60
Thanks for sharing, your work is beautiful, really nice looking trailer. I really like it
esteadle
 ;DNice. Have you put all the weight of your loader on it again since you beefed it up? I was thinking that you could maybe mirror the triangles on the back side. It looks sturdy enough for a good load of White Oak though. ;-o
Davek603
Woodmizer LT50 and lots of iron to go with it
Kbeitz
So what is the leg in the back for ? Looks like something that would hang up the trailer in a low spot ?
Love machine shop work
and Wood work shop work
And now a saw mill work
Dakota
I'm guessing it's so he can unhook it from the tow vehicle while loaded, and not worry about it standing on end.  My 02 cents.  That's going to be a handy trailer for snaking around the woods. Good job.
Dave Rinker
Skip
Be my guess too. pretty handy, good lookin trailer, nice job.
Brad_bb
So how will you load it?  Is this just for your property or will to be taking it elsewhere?
shop guy
2015 dodge Cummins 4x4 crew, t590 & 763 bobcat with hydraulic breaker, 1 woman, 1 baby girl, 3 dogs and a shop.
Blessed!!
God is great, beer is good....and people are crazy.
mrfu
Thanks for the great comments.
the green thing on the end is a brace to keep the front from popping up.
After it broke I added the two diagonal square tubes that run between the main tube and the outer ends of the axle support, I also added some 1/4 by 1 strapping under the axle support for strength.
I use it on my own property and load and tow it with my tractor. I have found that if I can't lift a log with my tractor it is too big to deal with on my mill
shop guy
Blessed!!
Rural
Not near as pretty as the trailer pictured above but after 8 years of very hard use I can say my trailer is 'beefy' having had it loaded up to the top of the side bars with hardwood. It is made from 2 x 2 x1/4 square tubing with full size wheels that are are set in so us not to wrap em around a tree on our narrow trails. Logs are loaded by directly winching over the back of the trailer up a removable ramp. Not fancy but functional!
samandothers
Nice trailers guys!  Thanks for sharing.
I skid some,and trailer some. The trailer is much easier on the woods. Does not leave marks going only 3-4 times in the same place.
