Fire Season Already - Neighbor Grass Fire Escapes
Started by ST Ranch, April 14, 2013, 10:39:47 PM
ST Ranch
We had a close call last Tuesday when my neighbour decided to try to burn a bit of a brush pile. About 2 PM in the afternoon, the wind came up and spread his pile across his pasture and into my timber land and pasture. Lucky my other neighbour had a 500 gallon water tank full of water and came to the rescue, but not after burning about 10-15 acres and about half the hair on my head. Wind was the killer, it kept gusting from all directions and real hard to control -no way to do a back burn.
Spent the next 2 days cutting fireguard and doing mop up and then on Saturday we got a snow storm.
Message of my story - 1] the weather is real UNUSUAL these days - VERY hot and dry one minute and then snowing the next, so be real careful with fire, even this early in the year.  2]  I have a 350 gallon water tank [see pic below] for my truck or trailer, but it was sitting on the ground, empty and the pump was in the shop. [Fortunately my neighbour was set up cuz he had been doing a bit of burning himself the week before and was prepared. - I was not prepared but will be now]
the top pic is looking east from my place  - this field burnt off in less than 5 minutes. Second picture is the snow on saturday - a real BLESSING in disguise for me.
Fortunately no one hurt, only a bit of spruce and poplar regen and a few mature poplar and spruce were burnt, but a good wake up call.
LT40G28 with mods,  Komatsu D37E crawler,
873 Bobcat with CWS log grapple,
ND rancher
You were real lucky, the US Forest service did a controlled burn on the ND, SD border several weeks ago on a windy, low humidity day. The intent was to burn 150 acres of grass,--- 14,000 acres later they finally got it out. The ranchers that were depending on grazing this summer are at a loss. The estimate is 1000 pairs with no where to go!  Keith
TimberKing B-20.  Have been bitten by the bug! Loving life !
Furu
Sorry to hear of your loss but it at least was not that bad.
On the topic of fire suppression, I am putting together a fire wagon trailer for prevention/fire suppression.  Sounds like what your neighbor had.
I have pretty much determined where I will get the equipment.  One of the suppliers is Cascade Fire Equipment.  They have a spot to input a coupon code for a discount.  Does anyone happen to know what the current code might be.
The other supplier is Fire Hose Direct and they do not have a discount code but I am always looking to save where I can.
Out in the open was dry here. Will be back to dry again real quick. We been having showers here off and on for a couple days. Won't take much for it to get back to being dry again. Have seen 2 fires on this hill. One right next to my lot,WOW!! and one just up the road. More WOW!! Glad no major damage for you.
ST Ranch
Thanks guys - YUP lucky is the story of the week for me!
My big challenge is trying to be prepared early, but it is hard to have a tank full of water and not freeze the closure valves at night - my overnight temps are going down to 27/28 F with day time highs of 60-70 F.  May have to look at some sort of heat [heat lamp in a box] or something.
The other big challenge and it sounds like you folks saw a bit of this in ND is the unusual wind events we are getting. Over the past 2-3 years, here in my area, we get afternoon wind events that are like small dust devils - in the bush they are blowing down single and clumps of trees here and there at random and out in the open they will pick up a windrow of hay and spread it everywhere.
This is what happened last Tuesday- wind event from afternoon heating and - you know the story.
In terms of setting up a tanker unit - I am using Honda high pressure pumps [WX15 and WX25 I believe] - they put out about 100 PSI which is good for a smaller tanker [200-500 gallon] -  they cost about $900 a piece, but always start and run all day if you have a good water supply.  I have about 15 -100 foot lengths of 1 1/2 fire hose for use if I have a pond or other ground source for water, but use 5/8 econo fire hose on the tanker [saves water] and easy to handle.
I have also found that logging suppliers and industrial hose dealers have better prices for hose and fire tools than the formal fire equipment suppliers.
I feel for the ranchers who lost their range - Up here, with the cattle market down and many old timers leaving the business, grass is not an issue cuz cow numbers are way down.
Would really take a normal light to keep it warm. Just have to make it to keep the heat in and the cold wind out. Maybe a box and a blanket or rugs,Or just through a blanket over it and the light under it?? Don't take much at those temps. I have no idea how big your valves are,a magnetic heater?
