Red Pine vs Spruce?
Started by shortaction, January 23, 2018, 08:02:03 PM
shortaction
Hi everyone, I bought a mill (Little Blue from Pascal Metals) in the fall and have cut a bit of eastern white cedar with it.  Enjoying it immensely.
I'm going to build a pole barn this summer and have access to some Red Pine 16' with 12 - 16" tops at a good price.  How is it for framing materials, mainly rafters and beam, plates.  There is some spruce available as well but it is fairly knotty.
Also want to cut some 8"x8"x 11' for the posts sitting on concrete sonotubes about 8-12" above the ground, I have some tamarack I was thinking would be good for that, any other suggestions would be appreciated.
I live in central/northern Ontario.
Really enjoy all the interesting threads and good knowledge on here.
Thanks in advance.
Todd
47sawdust
The red pine should work well for you.The spruce here in Vermont can be a challenge to saw.Wavey cuts.Some saw it frozen with better results.I don't know how the tamarack would behave as an 8x8,in board form it will twist badly if not well secured.
You might save yourself some grief and just use the red pine.My brother's implement shed is built entirely from red pine harvested and sawn from our property.
Best of luck to you.
Mick
Chuck White
Welcome to the Forestry Forum, shortaction!
For strength, The Spruce is first, then the Tamarack, then the Red Pine!
If you use the Red Pine for framing, don't go with 2X4, go with 2X6 or larger!
petefrom bearswamp
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
york
All the Red Pine that i have milled over the years and lots of it,would twist,hate the stuff....
Also,it is not decay resistant....Do you have any Hemlock???
Albert
barbender
Old growth and natural regen red pine is a different animal from plantation stuff. Natural grown is denser, heavier, and stronger than plantation wood.
KamHillbilly
I sawed some 6x6 tamarack last summer seems to be doing well definitely going to need something to move them when green those 8x8 x 11' are going to be heavy.what part of northern Ontario
Homemade Bandmill ,Clark 664b ,Case 780b ,Jonsered 670,630
petefrom bearswamp
No old growth or very little natural Regen here in NY.
have sawed some rp plantation and  made t&g paneling which my son has in his house it looks great.
Also OK for 2x4 and 2x6 stud which only need strength in compression
Kubota 900 RTV
shortaction
Thanks for the replies, everyone.  I think I'll go with the red pine as it will make fairly clear lumber.  Not sure what to use for the posts, don't like the idea of the red pine for there as someone mentioned, it isn't the most decay resistant.
Hemlock is not on the menu right now, but maybe I should ask some other bushwhackers if they can get me a few decent logs just for the posts.
The rafters will be 2x8 with a 12' span on 24" o/c and I'll put an 8' collar tie in as well.
shortaction
Quote from: KamHillbilly on January 25, 2018, 05:46:20 PM
I have a tractor with a front end loader to help with the heavy stuff.  I live just outside of Gore Bay, on the Manitoulin Island in the northern part of Lake Huron.  Good to hear about the tamarack.  If I wait until the sonotubes are poured, then saw the 8x8's and get them up with the plates and braces right away, hopefully that will stop them from twisting.
Chuck White
I like the idea of nailing Tamarack when it's green!   ;)
I had some red pine,no idea the same kind as yours. I was not impressed by it. I saw some 8x8 out and they twisted on me. I went back to hemlock.
I only cut spruce once. That takes a special band. I don't have a special band. That stuff went into the brush pile and every time I drove by it,it would wave at me.  :o
loganworks2
Nice area shortaction. The red pine will do just fine as posts as long as it is not in ground contact or constantly getting wet. I lived in Kentbridge Ontario when I was a kid and used to go to Manitoulin island fishing and camping at the campground on the south end of Manitoulin lake. We also spent a lot of time fishing at and around Emerald lake north east of Sudbury. This was in the late 60s the road to Emerald lake was just a goat path.
47sawdust
I visited Manitoulin with my wife 10 years ago.Her family used to go to a summer cabin on the North side of the island.I really enjoyed it.
As for as the red pine goes,treat the posts w/a preservative,I use old motor oil,keep it off the ground.If using for rafters or beams oversize it or make the spacing smaller.My brother's shed has 4x4's for post, nothing larger than larger than a 2x6 for framing.It has no big spans.I have had some twisting of the stuff I've sawn,after it was stacked and air dried.I was disappointed.Might be my sawing technique,might be internal stress or the nature of the wood.
Mick
shortaction
Where would a fellow find a chart for lumber that has the strength of different varieties of wood?
barbender
If Red Pine is clear it's a quite strong softwood. I don't understand all the calls for oversizing it.
Gearbox
Depending on the nominal size you will already be oversized if it is not planed . Steel roof ? If you do make it a dark color so the snow slides faster . Every building I have seen that went down from snow load was a white roof .
Chuck White
barbender, the reason I recommend oversizing Red Pine is because unless you get some really big RP, you'll have the whorls of limbs circling the log, to close together and therefore making a weak spot where the lumber is likely to crack or break!
The oversizing just adds a little meat to the material!  ;)
barbender
I agree Chuck, when using small diameter, young logs. But that would be true of any species. You NE guys give Red Pine a bad rap, it's our bread and butter 😊😊
barbender
BTW, happy birthday, Chuck!
firefighter ontheside
Red pine has served me very well.  I have a log home in Missouri built with red pine from Minnesota.  The ridge log is 43 feet long, but it's longes span is about 22 feet.  The log is about 24 inches at the butt end.  My house weathered a tornado.  Strong enough for me.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Darrel
Quote from: barbender on January 26, 2018, 11:21:47 PM
X2
And I can't help with the red pine, probably 1500 miles to the closest red pine tree.
1992 LT40HD
47sawdust
My reason for suggesting to oversize is just as a precaution.Not knowing the skill of the person building or the log quality I feel it is better to err on the side of caution.
Mick
