Three Generations of Saws [Homelite Stihl Husqvarna]
Started by 333_okh, January 28, 2007, 07:46:52 PM
333_okh
Just thought I would post a picture of the three saws I was cutting with today.  The big boy in front is a Homelite 7-21C [48" bar] from the late 50s, the middle saw is a Stihl 048 AV [36" bar] from the mid 80s, and the new firewood saw a Husqvarna 455 [20" bar].
logwalker
It is amazing how far they have progressed in 50-60 years. I'm sure glad they did. Are you getting much work out of that Homey?
333_okh
I use it on occassion, but try and keep the work to a minimum.  I will be going through the whole saw just as soon as I get an parts diagram and maybe a manual.
SawTroll
Quote from: logwalker on January 29, 2007, 12:49:20 PM
:D :D The 455 isn't a progress, it is a giant leap backwards regarding power to weight - on the alter of EPA.....
Information collector.
sawguy21
We best get used to it, the new emission standards are not going away. The 2 stroke as we knew it simply won't cut it anymore.
333_okh
--Photos MUST be in the Forestry Forum gallery!!!!!--.com/albums/p180/SCOPAC495/Chainsaws/Homelite5-30NA.jpg][img width=160 --Photos MUST be in the Forestry Forum gallery!!!!!--.com/albums/p180/SCOPAC495/Chainsaws/th_Homelite5-30NA.jpg[/img][/url]
Here! One is already up and running and the other will not be too far off.  They use 3/4 of a pint of SAE30 to a gallon.  If that isnt a soot burner then nothing is.
The 455 is a great saw and works just as it was intended.  If you need more saw, then go to the 460 or a 359.
smetr333
Nice saws.Here's a homelite site that might be of some help.
http://houseofhomelite.proboards55.com/
There was another member that was right into the homelites.This is where the site came from.
letsgetitracing
when the epa makes the chainsaws run 4 stroke motors they must be bringing a guy to each job to handle the extra weight eh? maybe that's how they will get the unemployment rate to drop? :D
Homemade firewood processor, 200 ton log spliter, 322 cat excavator, 966 c cat loader, 3 semis, 11 trailers, 50 ton low boy 12 inch tree chipper 3120xp 394 xp 372 xp 3 365  357 55 rancher 346xp 338xp  stihl 056 mag ms 290 026 echo cs440  4 cs3000's  jonsered 2165 2150
go BIG or go Home
arojay
Quote from: sawguy21 on February 01, 2007, 01:13:54 AM
That depends on the "it" you have to cut.
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
Al_Smith
Quote from: smetr333 on February 13, 2008, 12:38:04 PM
DO YOU KNOW THE CC OR H/P OFF THE 048AV
76.7 cc  .HP between 5.5 and 6 depending on who you talk to.What ever,it's enough. ;)
SawTroll
Quote from: Al_Smith on February 16, 2008, 03:09:55 AM
My info (from Stihl) say 5.2hp.
Urbicide
Quote from: letsgetitracing on February 14, 2008, 09:28:11 AM
Do you think that two-man saws will be making a come back?
Or how about drag saws?
Who wants dibs on the dumb end? ;D ;D ;D
