My new yard layout
Started by DGK, April 06, 2012, 12:45:14 AM
DGK
Since I stopped cutting firewood last year and subsequently gave up my industrial lot, I had to set up the sawmill on my property. Here is a pic of the mill in the small area that I have allowed myself to work within. It is too easy to cut down the tress and chew up the property with the bobcat to make more room. It's a residential lot that is quite beautiful and I want to keep it that way. The slabs go into the grapple where I strap them then move them out of the way.
I cut, stickered & stacked 800 ft of 4/4, 8/4 and 6 by 6 today without help. The workflow worked well, except for the wind blowing from the wrong direction. :-)
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
Brucer
The wind always blows in the wrong direction ::).
Nice layout!
Bruce    LT40HDG28 bandsaw
barbender
That looks very well organized and neat. I can't even bear to post pictures of my "layout".
It is difficult staying neat and organized and it looks like you have mastered the art very well.  What do you actually do with the slabs?
DGK
The slabs get bucked into stove length and are used in my wood boiler as either kindling or the larger pieces to get a good hot fire going. I strap them as it allows me to pick them up with the bobcat and drop a load into the back of a pickup truck easily as well as buck them with the chainsaw using a long bar all at once. A bit of extra work but it pays off in keeping the mess manageable.
Doug
Yukon, Canada
I thought so, but I wanted to hear your process.  It certainly sounds like you have your entire operation in order.   smiley_thumbsup
POSTON WIDEHEAD
DGK, Now that you have your place in order, can you come down and start on my Son's room?  :D
