rockler turning tool
Started by Tony, March 16, 2007, 02:43:00 PM
Tony
 Saw this turning tool in the rockler catalog;
http://www.rockler.com/product.cfm?Offerings_ID=17354&TabSelect=Details
Hunter #4 Round Turning Tool
Has anybody had any experience with it?? I'm  trying to upgrade my lathe tools.
                                  Thanks, Tony    8)
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
metalspinner
So what tool are you trying to upgrade with this one?  I can't figure out from their desciption how this tool is supposed to cut.  Is it a scraper?  From the looks of the shaft, you cannot extend it too far past the toolrest.  It will probably really chatter.  The replacement inserts seem kind of high.  You can probably get them cheaper through machinery catalogue's.
Tony
    metalspinner,
They claim that it would be used as a bowl gouge and
it would work "even on end grain" ??? ???  The catalog came
the day I tried to turn a bowl out of osage end grain  ::) and
I thought it might work ::).  As usual the FF is a good place
to ask my many questions and get good advice  ;D ;D
                             Tony  8)
Fla._Deadheader
I'm fixin to make a few different shapes with Inserts for cutters. Gotta be good with Carbide cutters. Can't keep tools sharp with CR hardwoods  ::) ;D
low_48
The bad thing about carbide is that you can't get it as sharp as high speed steel. For a really good quality scraper you need a burr to make a good cut. It works just like a cabinet scraper, without the burr you get dust. I can't comment on this particular tool but I do know that some of the new insert profiles do have the geometry designed for cutting wood. Not like the old days of trying to use metal cutting inserts for woodworking.
metalspinner
QuoteNot like the old days of trying to use metal cutting inserts for woodworking.
I was about to post a link to a metal working supply house for inserts for that tool.  They are only $2-$3 each.  It may still be worth a try considering a replacement insert for the tool above is $20. ::)
www.kbctools.com
Item #RNMG-43  get'syou to the right page of inserts that look close to what is on the turning tool above.
Well, I just checked the link and they are under construction. ::)
JimBuis
Hi Tony,
I am not familiar with that particular tool. However, I don't like tools of that sort that require me to regularly buy replacement parts. Have you looked at Lee Valley's assortment of gouges? www.leevalley.com
I have bought several of their's and like them a whole lot. Those I can comment on.
Jim
Jim Buis                             Peterson 10" WPF swingmill
