Husqvarna 340
Started by gjskerman, October 24, 2019, 09:39:49 PM
gjskerman
Is there a gasket required between air intake manifold & carby on a Husqvarna 340
weimedog
Cylinder-Intake boot with clamp, make sure you put on a new style STEEL clamp to hold that boot to the cylinder. There is a support ring at the carburetor end of those boots. Then that "bracket" presents the sealing surface of the boot to the carburetor ... no gasket there.
Did this video on a 345...same saw really.
https://www.youtube.com/watch?v=wyVcMZw3Jr0
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
gjskerman
Thank you weimedog for your reply much appreciated
I meant at the air filter end not the cylinder end
The service manual doesn't seem to show a gasket which seems strange to me
Cheers
Geoff
dougand3
There is rarely a gasket upstream of the carb throat - between carb and air filter box (housing). All that matters there is a good enough seal not to get dirt, sawdust ingested.
gjskerman
