Adding Hydraulic Accumulator?
Started by quadracutter222, February 01, 2019, 09:09:20 PM
quadracutter222
Down the rabbit hole again, seems every phone call I make, opens up a new door to a recommended upgrade.  It was suggested I add a hydraulic accumulator to the tensioning system on the mill.  I think I have a good understanding of what they do and the gains it would add, but not sure if a) its worth it and b) where it would go?  I *think* it would go between the pump and the valve?
There are calculations to do based on piston size to do, so size the accumulator and determine new pressure, but wanted to get y'alls insight.
JB Griffin
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
charles mann
yes, it should go between the pump and a valve or solenoid. it will also act as a spring, so to speak, for any surges that happen with the movement of the band during operations.
Temple, Tx
