lt40 brake band repair
Started by pineywoods, August 19, 2017, 11:44:46 AM
pineywoods
Noticed the band was taking longer than normal to stop when clutch was dis-engaged. Bake band was worn down to metal on metal, no lining left. A chunk of 2 inch wide leather pants belt, gorilla glue, and couple of pop rivets and now good as new. Engage the clutch to take pressure off the brake, glue and pop rivet the new lining in place, the dis-engage the clutch to hold the new lining in place until the glue set up. Notice there was a bit of squeeze out  ::) That big ole spring in the pic is part of another mod, described in the useful sawmill mods thread.
fishpharmer
Pineywoods, well done and thanks for sharing.    8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
I would expect no less from you my friend.  Well done.
pineywoods
Thanks my friends. This is the second one I have done. I seem to have a good supply of leather belts that have shrunk so much in length they are no longer usable.  ::)
Kbeitz
Contact cement works great for brake band glue.
Love machine shop work
and Wood work shop work
And now a saw mill work
