A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
Peter Drouin
Rain today so I thought you all would like to see this job. when I got to the job today I saw this :D :D :D A few logs all ln a row. so I set the mill up.
  The customer gave me the cut list and I started. the customer did a good job to line up the logs, but sometimes they get out of alignment . so I made a log mover for my self.
  It will work with any mill. just some 5" wheels and angle iron. the limbs are cut flush to the tree. I just roll the log up on it, I have 4"x4"x4' in front of it.
  just push the log sideways and your all lined up. will work with biger logs to.
  I use it all the time. it was hot to day so the umbrella came out today not to burn my but.
  and at the end of the day I blow off the mill. I have a aircompressor that I bring with me.
  I like to use a small tip, so I can get in all those small places. I like to blow out the filter too
  and then cover the mill and go home :D I made a small dent in the pile. ill go back wednesday
Norm
Now that's a big job! Cool idea on the log mover too!
That is a nice whack of logs and a very good idea on the log mover/aligner.
What dimensions of lumber are you sawing?
bandmiller2
Pete,good idea on that log evener,we just used the roller toe boards but only works if your on them. Frank C.
ladylake
A tapered slab in the middle of the logs lets you steer it easy as you roll it also, looks like a week or so of cutting  , might have to move the mill closer to pile after a coulple of days.  Steve
dblair
I like that log aligner . Nice whack of logs also.
old Appomattox Iron Works circle mill.
I like for the log pile to be at least 10' from the sawmill so I can adjust them with a 4"X4" as Steve suggested above.
I do have roller toe boards, but whatever method that you use, it is far easier to always have the log adjusted before it is loaded onto the sawmill.
Most times for minor adjustments on 8' logs, I roll it back onto the loader pulling the long end first and then back onto the sawmill pushing the long end first.
A good idea. What kind of wood? Rain here today too.
Chuck White
Great Whack O Logs Peter!
I like the idea of the "log shifter", must save a lot of hastle.
markd
Peter, looks like you have a good system workin for you there, good job! Markd
markd
Peter Drouin
All the wood is w pine and hemlock. the cut list is for a 24x50 barn. the customer had me cut some dry wood for the sticking. my wood, he did not want to use green wood. and yes ill have to move the mill in. I do use a tapered slab to steer the logs. but the log shifter has been a good thing to get them lined up a big help to me. the next job is just as big and the phone is ringing off the hook with lumber orders.  :D :D
Al_Smith
Clever idea .Egads you'll have a pile of saw dust before that job is done no doubt .
cutterboy
What a beautiful sight! All those logs lined up nice and pretty. Looks like you'll be busy for awhile. I love your log shifter.....very clever. Hey, and thanks for all the pictures.
I just finished my first portable job, and I was running into the misalignment issue. I like Peter's solution, I was thinking a small arch would be slick too.
It does not get a lot better than that.
I agree WDH, that is a dream job for sure.   8)
Peter Drouin
well I got at the job today and all the sawdust was gone and all the slabs . so I got out the atf and painted all the parts on the mill that move. :D
  fuel up sharp blade and here I go :D well the log shifter is not perfict the hook on the mill will get it sometimes
   on the cut list are some beams. the WM will cut nice and square but I check, I have a small square that I keep by my feet on the chair.
  but sometimes I over clamp. so I will shave the cant so its square
  I keep a pv on each side ov the log pile I think you can see them in the pic
  when im cutting I have to look out for the outside wheel the sawdust will get in there and stop it from turning :o
  .all and all to day went well. maybe after thursday ill have to move in. 2 days and I think im half way maybe :D :D :D
   :D
That pile looks like it keeps getting bigger.  Maybe the wood nymphs are secretly adding to it at night after you leave.  You may never get finished  :D.  It could be the Hotel California of logs  ;).
JohnM
Quote from: WDH on May 02, 2012, 10:28:53 PM
Quote from: Peter Drouin on May 02, 2012, 09:03:38 PM
well I gut at the job today and all the sawdust was gone and all the slabs too.
The nymphs take the slabs and dust, glue up 'logs' and put them on the end of the pile. ;D :D
JM
Lucas 830 w/ slabber; Kubota L3710; Wallenstein logging winch; Split-fire splitter; Stihl 036; Jonsered 2150
Nymphs are like that  :D.
customsawyer
If you didn't have it all under control I would offer to come and help. ;D
www.thecustomsawyer.com
Peter Drouin
Thanks costomsawyer  :D  things are going good, but today it rained well a drizzlr. made some wet sawdust :D  to much work ahead to take a day off. :D I have logs to cut at home and under a roof, and only one mill :D  I dont want to pull the mill back and fourth. so I though if I leave 40 at the barn and tied to the 24' ex  I could cut while its raining and leave the new 50 at the job all covered up and I could stay dry :D :D I had to cleen up my sawdust this moring, just to tired yesterday
  you guys are right the other log pile is growing :D
   I caught the arm with a pice of stking and bent it ,when I bent it back  :o
  it broke :D :D :D :D :D i did it before ill fix it again... I think its time to move the mill up for fridays cutting
   then bring it home to fix it and saw more logs , for a lumber order :D :D when I leave a job and kids live there I try to fix the logs so they dont move
  I try. the costomer wants to buy some dry stikens
  can do :D :D ;D
Peter Drouin
Well to day it rained , went and got the mill, muddy :D got home and fix the arm
  pant it black and done
  well I had the welder out ;DI have wanted to do this for a while . I removed a  back stop off the 24' ex and put it on the mill
  Because sometimes when I turn A long cant it will hit the stop and chip the beam
  It should stop that from happening :D
   Boy dont that WM orange look purrrrrrty . look so good I allmost painted the hole mill :D :D :D :D that WM paint lays down well.
  the mill is ready to cut  :D :D
  and the toys are in the barn
   :D :D :D :D I hope the sun comes out tomorrow
Good job.  I missed it before, but you are loaded up with Fine Adjust Outriggers too.   smiley_thumbsup
I'm short of time- too many projects, and I was really stalling about getting to this job. Problem was, the fella kept growing the pile the longer I waited :D Normally I'd be overjoyed to have a nice whack of wood to saw, but the construction loan on our house is due in 2 months, and I have a long wayto go yet. In fact I shouldn't even be on the forum probably :)
