parbuckling
Started by board, March 14, 2014, 06:28:02 PM
board
To parbuckel a log on the mill can I hook the chain to the mill or does that put to much strain on the frame ?  Its an ezboardwalk 40 and has 6 inch channel iron for the frame.
paul
kelLOGg
That sounds like plenty enough frame to parbuckle but I would like to see a pic of the angles involved. I assume the stationary end of the parbuckling cable is fixed to the mill frame and the end going to the winch is several feet higher than the frame. My frame is 3 x 6 x 3/16 and I parbuckle as I described.
Bob
goose63
If the winch is high enough you wont hurt 6 inch chanel
goose
thank you to all the vets
Ga Mtn Man
I dragged my TK 2000 sideways once parbuckling a massive oak log onto the loader arms using a winch mounted on the mill.  Moving the fixed attachment point to a tree on the other side of the mill solved the problem.
board
I would be using a winch attached to the opposite side of the mill also the log turner for the ezboardwalk. Its about 5 ft. above the bed and the mill is about a foot off the ground, might raise the mill a little to save on my back.
paul
drobertson
I am thinking with some cables them logs will roll right on up without much strain on anything. I would say go a lil slow, and watch for the big end to gain on the smaller end, and get on with it.   Chains work great too, I just like the wire rope, for this type of work,
kelLOGg
Quote from: board on March 14, 2014, 09:34:08 PM
IMO, you won't have any problem.
My mill is 2' off the ground, winch is about 5' off the ground on a swinging mast and the tie point is ~3' off the ground, also on the mast; the mill will tilt when loading ~4000 pounders. Your tie point is much closer to the mill so you will be even better off. It would have been a better design if I moved my tie point closer to the mill. Didn't consider it til now.
Bob
Bob
justallan1
Remember, the higher the winch and the longer the ramps will reduce the pull greatly. My trailer is 3' high, my winch is 4' above that and my ramps are 8' long. I pull 16'x16-20" pine logs on it with a $40.00 Harbor Freight winch. Granted, on my set up I'm tying off on the trailer, but I really doubt it would be any different if I were pulling on the tracks.
Allan
