Today is the Autumnal Equinox, known in layman's terms as the first day of fall.
Started by Chris Burchfield, September 22, 2010, 07:59:12 AM
Chris Burchfield
Starts about 11:a.m.  I think I enjoy this season the most because my house air conditioner went on the blink last night.  It was 80°F when I laid down in the bed last night windows open and box fans in three of them.  The fan outside was not working. The inside blower was.  I don't know how to check the motor start capacitors.
Woodmizer LT40SH W/Command Control; 51HP Cat, Memphis TN.
Cedarman
I don't like fall because it means winter is coming and I hate winter.
trapper
ScottAR
Easy thing to check is take a longish screwdriver or a stick; something that fits through the grill and spin the fan by hand a little.
Sometimes they'll take off and you need a hard start kit.  Basicly a piggyback capacitor.
Scott
[Magicman]
Radar67
Chris, I had a similar incident with mine. It ended up being the soft start PC board gone bad. It happened late one evening and I found a solution until the AC guy could come. I removed the control panel cover and found where the three wires connect to a block. The center wire had a spring loaded thing that contacted when pushed in, and the fan would start. I jabbed a screwdriver in it to hold it in place and it ran the whole night. The AC guy was impressed.  ;)
I am by no means recommending you do this, if you do, it is at your own risk.
Chris Burchfield
I pulled the disconnect at the compressor.  Set the thermostat for air conditioning then set the temp to 65.  Went outside, plugged it back in and gave the fan a spin.  It started up.  Pulled the power cover.  Found the starter capacitor puffed out on both ends.  The side with the wire attachments was bulging and discolored from heat.  Replaced capacitor, we'll sleep cool tonight.   :)
isawlogs
   Marcel
Mooseherder
Brucer
1 deg C (34 F) last night and up to 12 C (54F) during the day. That's why Canada has Thanksgiving in early October ;D.
Bruce    LT40HDG28 bandsaw
ScottAR
Scott
[Magicman]
Chuck White
We've had a couple of frost's here, with temps at 30° & 32°.
I like fall because that's when hunting season starts, 8) but that's also when sawing season (for us) ends. :(
