Author Topic: What is the best way to remove two BIG tree remains ?  (Read 760 times)
Offline joer00
  • Member*
« on: April 17, 2018, 08:46:08 PM »
Hi,
I had a company cut two huge trees but after I paid them 70 % they run away and left me with two big tree remains. Approx 10 feet high and with a diameter of approx 5 feet. I have a 23k pound wheel loader with a root rake, but the trees only laughed at me ! The loader broke and while fixing it I cut the roots around the tree with a stump grinder.
Besides the loader I have a 40 ton old crane on the lot. What is my best way to get those trees down ? See images below
(don't know why second one is turned, looks correct on my computer)
Offline Southside logger
Re: What is the best way to remove two BIG tree remains ?
« Reply #1 on: April 17, 2018, 09:45:14 PM »
Welcome to the Forum,
Those are big for sure.  Were they dead or otherwise compromised?  If so that could complicate accurately felling what is left.  Do you have access to an excavator?  The roots could be quite deep and include a tap root so the stump grinder may have only gotten what you could see.  Digging around them with an excavator will make for a big hole, but at least you can control which way it goes.  I would not try to whump it over with anything for the reason you already learned.  I also would not use the crane to try and pull or otherwise rip it out, else you could end up on youtube.
Offline mike_belben
  • Pulp Friction
« Reply #2 on: April 17, 2018, 10:24:52 PM »
If you intend to pull the stumps, soak that trench with water and try again, pushing with the loader from up high.   If it doesnt wanna go, use your root rake to disturb the ground, then a pressure washer or garden hose to keep washing the dirt away and use a sawzall with a nail blade to sever more roots.  again push from up high, same side as where you cut.  You just keep soaking, finding roots to cut and pushing until it gives.  With a loader and crane youll eventually win.
Revelation 3:20
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
« Reply #3 on: April 18, 2018, 02:07:17 AM »
without a decent excavator, that's going to suck. I'd get as high as I could and start taking it down in manageable chunks. Ultimately ending up cutting it as close to the ground as I could then finish up with the stump grinder. Wait 5 or 6 years and fill in the hole that show up.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Broccoli remains...
Started by mrcaptainbob on General Board
Last post June 26, 2012, 11:44:13 PM
by beenthere
What Happens when U wrap the remains of a 372XT around an AM short block?
Started by weimedog on Chainsaws
Last post July 24, 2018, 10:35:43 AM
by weimedog
Remove the powerhead!
Started by TexasTimbers on Forestry and Logging
Last post March 24, 2007, 10:23:08 AM
by snowman
Please remove this post
Started by beamero on Sawmills and Milling
Last post November 02, 2014, 07:24:33 PM
by beamero
