Author Topic: drying Dogwood  (Read 1000 times)
Offline xlogger
drying Dogwood
« on: May 03, 2018, 08:29:47 PM »
Got a guy that wants to bring over some live edge dogwood slabs,  he said they were crotch cuts. I've not seen any dogwood myself that was big enough to make slabs. But who knows. He said that they are around 20% MC. Anyone dried dogwood before? He only has a few 4 ft slabs, wonder if I can just put them in with some maple that I just put in the kiln and they were around 20% also.
Or better yet maybe I should just send him to Scott :D
Offline Southside logger
Re: drying Dogwood
« Reply #1 on: May 03, 2018, 09:27:21 PM »
If you do get them post a photo - I have never seen dogwood sawn.
Offline Texas Ranger
  • Texan, by God and by choice.
Re: drying Dogwood
« Reply #2 on: May 03, 2018, 10:28:12 PM »
I have worked dogwood, beautiful stuff, but sensitive to mold and such, tell your client you are not responsible for color change.
Offline xlogger
Re: drying Dogwood
« Reply #3 on: May 04, 2018, 06:01:10 AM »
If he does bring them today wonder if I stand them up on a wall inside kiln. I hate to unload and re baffle the load again. If I do he going to pay extra. Also wonder what # on my Delmhorst should I use to test MC?
Offline K-Guy
    • http://www.nyle.com/
Re: drying Dogwood
« Reply #4 on: May 04, 2018, 09:07:57 AM »
Putting the dogwood in with the maple is no problem. If it is below 20%, mold shouldn't be a problem.
If it barks, I recommend smacking it on the nose. :laugh:
Nyle Kiln Sales & Service
Offline xlogger
Re: drying Dogwood
« Reply #5 on: May 04, 2018, 03:56:51 PM »
as long as it doesn't bite ;D
Offline GeneWengert-WoodDoc
Re: drying Dogwood
« Reply #6 on: May 04, 2018, 09:58:15 PM »
There might be something funny here, as the largest dogwood trees are seldom over 18 in diameter. For example, the single largest in Texas is about 22 in diameter.  Further, the height of dogwood is around 30 feet which means the lower section is fairly knotty.  Tension wood will be abundant.  Flat drying will be tough.  Cracking is likely.  Make sure your customer knows you will do the best, but wood quality may result in poor results. Maybe you need a partial payment up front.
In terms of drying, use the persimmon schedule.  For color, treat it like hard maple, not soft maple.  But, with crotch wood we have unusual shrinkage.
As far as the moisture meter, the species correction at low MC is very small with a pin meter.  I would use hard maple.
Offline kelLOGg
Re: drying Dogwood
« Reply #7 on: May 06, 2018, 07:46:54 AM »
I air dried a dogwood black 6 x 6 x 30 (approx.) and splitting occurred fast. This one was cut about 1 to 2 years ago.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Drying Dogwood
Started by The WoodYard on Drying and Processing
Last post October 26, 2016, 07:57:11 AM
by WDH
dogwood
Started by slider on Sawmills and Milling
Last post March 23, 2014, 08:48:41 AM
by Magicman
silky dogwood
Started by chuckp on Tree, Plant and Wood I.D.
Last post October 27, 2007, 12:37:36 PM
by chuckp
Solved: Dogwood
Started by Don P on Tree, Plant and Wood I.D.
Last post March 31, 2002, 05:27:11 PM
by Don P
