Council Tool
Author Topic: What's your choice?  (Read 1911 times)
Offline ReggieT
What's your choice?
« on: May 07, 2018, 01:59:23 AM »
Got a chance to grab a couple truck loads of green firewood to season for 2019.
Both of them are free of charge, but here is the kicker.
I can only nab one species per the landowner!
I've asked him a couple times why I can't mix em...and he just goes into a demented diatribe! smiley_furious smiley_bucktooth
Shagbark Hickory or Honey Locust!!! ::)
I've burnt bunches of black locust and a little
shagbark...not real familiar with Honey Locust.
I know that carpenter ants seem to have a real passion for the black locust.
Which one would you studs choose? ???
Offline Ianab
Re: What's your choice?
« Reply #1 on: May 07, 2018, 02:19:12 AM »
Honey Locust is great firewood, but if I was collecting it, I'd probably go with the Hickory as it doesn't have the nasty spines.
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #2 on: May 07, 2018, 07:10:03 AM »
That's a great problem to have. 👍 :)Usually I'm stuck with scrounging the junk wood.
HeatMaster dealer support in VA.
GS100.
Online LeeB
« Reply #3 on: May 07, 2018, 07:30:59 AM »
As far as burning goes I would take the hickory over the honey locust. The honey splits easier though. Hydraulic splitter is nice for either one. The honey locust needs to be well seasoned. I burn it because I have it and the wife doesn't like the trees. I cut them down and make firewood out of them. No sense in wasting firewood I paid for.
Offline hedgerow
« Reply #4 on: May 07, 2018, 08:56:55 AM »
For me the big question would be is the honey locust thorn or thorn less. Around here we have both with the locust and the thorn type just go in to the brush piles and are burned. If it has thorn's I would go with the hickory.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #5 on: May 07, 2018, 11:42:18 AM »
I'd take the Hickory, sell it to a BBQ restaurant, then look for other wood for firewood.   ;D
BTU wise, it's basically a tossup.  27.7 versus 26.5 for Hickory and HL respectively.
I don't really care for cutting Hickory bark as it seems to hold dirt and dull chains quicker, but it beats giant thorns.
Now if the Honey Locust is thornless, or has been dead a while, thorns are no longer an issue.  At that point it becomes what is the easiest to get to etc.
Lucas 6-13+slabber, Mr. Sawmill bandmill, orange chainsaws, JD SSL, Case Backhoe, farm tractors, trailers, and 150ish acres of trees.  Fledgling woodshop with CNC router, laser engraver, Woodmaster 712, and a Berlin 108 moulder (project).  Oh, and a lovely (patient) wife and four offbearers.
Offline KEC
« Reply #6 on: May 30, 2018, 10:45:30 PM »
As another stated, honey locust is stubborn to dry, but a big piece of it along with something that burns more readily will hold a fire a long time on a long winter night.
Offline ReggieT
« Reply #7 on: June 02, 2018, 04:45:10 PM »
Yep...I've noticed that black locust is not the easiest to catch on...but man the burn time is almost unreal!
Offline KEC
« Reply #8 on: June 05, 2018, 09:35:48 PM »
If you cut Black Locust and let it lie for a few months, then score the bark lengthwise with a chainsaw, the bark will come off with an axe. Upgrades that wood considerably with that thick bark off. Don't worry about the wood going bad, it's rot resistant.
Offline ReggieT
« Reply #9 on: June 12, 2018, 02:21:13 AM »
You know like to burn black locust bark? :D
I just started a huge stump burn with hedge/blk locust scraps, starter fluid, some charcoal!
Offline hedgerow
« Reply #10 on: June 12, 2018, 08:53:29 AM »
I love to burn that hedge.
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #11 on: June 13, 2018, 04:00:58 PM »
Go for the hickory. It's a very dense wood so will burn a long time and give a lot of heat. But it can be hard to split. If you have a wood splitter it won't be a problem.
Has Anyone Made a Pick Up Rack From Wood (1st Choice) or Metal (2nd Choice)
Started by H60 Hawk Pilot on General Board
Last post October 19, 2010, 08:43:42 PM
by jbeat
Need help with atv choice
Started by Timbercrk1 on General Board
Last post June 07, 2010, 11:56:29 AM
by Raider Bill
Choice
Started by Jeff on Chainsaws
Last post December 06, 2013, 02:23:23 PM
by MattJ
Blade choice?
Started by newstick on Sawmills and Milling
Last post May 01, 2016, 05:39:58 PM
by Dave989
