Stilh Ms 290 farmboss
Started by boboyee58, May 15, 2018, 11:34:49 AM
boboyee58
Stalls out when chain brake is applied
boboyee58
Stalls out when chain brake is applied looking for a fix I think it's the clutch but not sure
sawguy21
Welcome to the forum! Either the sprocket bearing is seized or the clutch has come apart. Pop the clip off and remove the drum.
boboyee58
already tried new bearing and new clutch springs
ZeroJunk
Did you clean or replace the drum ?
If the chain isn't turning at idle I don't see why the brake would do anything.
It shouldn't be.
boboyee58
Did not replace drum and chain is moving at idle
Hilltop366
Does the clutch drum turn freely by hand with the saw shut off and cover removed.
BradMarks
"Chain moving at idle" indicates a very loose chain, or too high idle rev, or both. I have an old 026 that if the throttle gets goosed with brake on it will sputter out, as if flooding the carb.
boboyee58
Clutch cover turns freely by hand with a little squeal
boboyee58
Remove clutch cover cleaned everything thoroughly reassemble and all is good.
Thanks for all the input
Hilltop366
Weekend_Sawyer
My neighbor brought his 250 over with the same problem. The clutch was filled with debris. We cleaned it out and she works fine now.
About every 2nd sharpening I flip my bar. While I have it apart I blow everything including the bar channel out with air. Makes me and my saws happy.
Jon
Imagine, Me a Tree Farmer.
