TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: stihl ms 170 handle buffers  (Read 651 times)
Offline 2308500
« on: May 18, 2018, 02:50:59 PM »
Can new buffers be installed into the ms 170 engine casing WITHOUT removing engine and fuel tank or do i have no other choice but a complete teardown.
i have the old ones taken out without too much difficulty and im wondering if lots of lube will get em into place without tearing apart the whole saw
Offline dougand3
Re: stihl ms 170 handle buffers
« Reply #1 on: May 18, 2018, 04:44:25 PM »
Sure you can get them in. Lots of play with handle. Shouldn't need lube.
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
Offline 2308500
« Reply #2 on: May 18, 2018, 04:52:04 PM »
handle side i cant see any problems but casing side looks mighty tight
Offline 2308500
« Reply #3 on: May 18, 2018, 11:43:49 PM »
update
tried and tried but i wound up having to unbolt engine from casing.  was able to move cylinder enough to pull plug out, insert buffer and reinstall plug
wasnt bad took about an hour while chatting with the boy :)
question
Stihl MS460 Handle?
Started by rangerbob on Chainsaws
Last post January 24, 2005, 08:32:08 PM
by BC_coops
taking apart stihl 34 handle
Started by sbishop on Chainsaws
Last post March 24, 2006, 11:51:03 AM
by sbishop
Want to buy good used stihl that will handle a 22 " bar
Started by 60lp on Wanted
Last post January 18, 2014, 09:46:53 AM
by 60lp
Stihl heated handle wraps
Started by CMI80 on Chainsaws
Last post December 02, 2017, 08:36:00 PM
by ehp
