Author Topic: Wheel weights on a Kubota  (Read 1644 times)
Offline firefighter ontheside
  • I like trees.
Re: Wheel weights on a Kubota
« Reply #20 on: June 01, 2018, 03:09:51 PM »
That settles it.  I知 making concrete wheel weights and painting them orange.  I will place j bolts in them right where they need to be to fit the wheels.  Just need a good form to use.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline mike_belben
  • Pulp Friction
« Reply #21 on: June 01, 2018, 09:56:11 PM »
Metal drum cut in pieces with steel conduit welded to the holes you make in bottom.  Id tack a few pieces of rebar inside to keep them from bulging or dropping the whole puck out.
Weld an eyelet to the outside so that you can use a hoist to help put them on or off. Itll be a handful.
Revelation 3:20
  • I like trees.
« Reply #22 on: June 01, 2018, 10:48:56 PM »
Yes, putting them on will be a trick.  I wish I could use the loader.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Skeans1
« Reply #23 on: June 02, 2018, 12:00:15 AM »
Got an engine hoist?
  • I like trees.
« Reply #24 on: June 02, 2018, 08:17:35 AM »
No, but I値l think of something.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline Hilltop366
« Reply #25 on: June 02, 2018, 08:29:24 AM »
If you make the wheel bolts accessible with some plastic drain pipe you could mount the weights first then mount the wheel on the tractor. Some blocking and leverage to stand the wheel up after the weights are secured.
Offline mike_belben
  • Pulp Friction
« Reply #26 on: June 02, 2018, 11:44:42 AM »
Alright then roll it up a plank onto your floor jack positioned at the bulge of the tire.  Raise to height with the jack, steer into position with a rope tied off to your seat bracket, looped through the top eyelet or weld loop or whatever you decide to use for anchoring.  This top rope will also help prevent dropping it on yourself.
Have a ratchet strap rigged up so you can cinch the puck against the tire and be free to crawl behind and pass bolts through.  I tack weld nuts to all thread when i need a long bolt.  Just beware its low grade and stretches/snaps pretty easy.
Revelation 3:20
Wheel Weights
Started by ncsawyer on Sawmills and Milling
Last post December 10, 2016, 10:53:32 PM
by Andries
Opinion: Band wheel w nothing btw blade and wheel
Started by chisel on Sawmills and Milling
Last post June 14, 2004, 02:26:41 PM
by Fla._Deadheader
Log weights
Started by Robert R on Forestry and Logging
Last post October 28, 2005, 10:17:33 AM
by OneWithWood
Log weights
Started by Sawyerfortyish on Forestry and Logging
Last post October 14, 2004, 07:16:19 PM
by Sawyerfortyish
