Author Topic: Need a new sprocket for a PWR33CCCSA  (Read 879 times)
Offline TonyRogers
« on: June 01, 2018, 12:40:15 PM »
 PIve just picked up a cheap second hand chainsaw, model no as in the title.
The engine runs beautifully but the drive sprocket is absolutely shot.
Does anyone know where I might be able to get a new sprocket (& I'll need a new chain too!). Or another model that has the same sprocket?
It's a 3/8 chain, 6 tooth sprocket. Centre spindle is 7.8mm, internal diameter of clutch surface is 62mm.
I'm in the UK.
Offline sawguy21
Re: Need a new sprocket for a PWR33CCCSA
« Reply #1 on: June 01, 2018, 08:58:14 PM »
I don't recognize that model number. What is the brand?
Offline dougand3
« Reply #2 on: June 01, 2018, 09:20:13 PM »
Is the saw like a newer 33cc Poulan?
Sprocket looks like Poulan except above is ribbed. Is it a normal 2 shoe clutch?
Maybe this is close:
Poulan / Husqvarna part number:  530057905
Sprocket Kit is for a 3/8" Low Profile, 6 TOOTH System
SPECIFICATIONS:
3/8" Chain Pitch
6 Tooth Drum
Outside Diameter 66MM
Drum inside diameter is 64mm
Drum Inside Depth is 15mm
Bearing inside diameter is 8mm
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
Offline TonyRogers
« Reply #3 on: June 02, 2018, 01:59:40 AM »
That sounds about the right size, thank you very much.
Is there a table somewhere that shows a list of part numbers with these dimensions for each? I've looked everywhere!
Also do you please have a Husqvarna model number or two that this fits, as that would make it easier for me to find a pattern part.
Offline dougand3
« Reply #4 on: June 02, 2018, 08:39:17 AM »
I've never seen a table with part dimensions - maybe one exists, tho.
This is Husqvarna part # 530057905. (Husqvarna owns Poulan).
Some USA online sellers list the models a part will fit. This 530057905 only lists newer 40cc and smaller Poulans.
Maybe you can take the sprocket to a Husqvarna dealer and try to match.
Post a pic of the saw.
Poulan: 4218, 2000
Offline TonyRogers
« Reply #5 on: June 03, 2018, 12:57:01 PM »
Could you please point me at the list of husky saws that 530057905 fits?
Thanks.
Offline dougand3
« Reply #6 on: June 03, 2018, 04:48:38 PM »
As I stated above....This 530057905 only lists newer 40cc and smaller Poulans.
This site shows the saws it fits:
Clutch Drum [530057905] for Power Tool | eReplacement Parts
Poulan: 4218, 2000
3/8 lo pro rim sprocket
Started by Caloren on Chainsaws
Last post June 22, 2015, 10:48:46 PM
by joe_indi
Rim Sprocket for MS 460
Started by Good Feller on Chainsaws
Last post July 28, 2008, 01:13:30 AM
by Southernlogger007
385 with 8 sprocket...
Started by Ever Green on Chainsaws
Last post March 26, 2006, 10:40:30 AM
by Rob
034 sprocket
Started by Cliniford on Chainsaws
Last post December 21, 2008, 08:19:09 PM
by Cliniford
