Baltic Abrasives Technologies
Author Topic: Tree farmer  (Read 1744 times)
Offline mjeselskis
    • Big Rock Lumber
Tree farmer
« on: June 03, 2018, 01:45:46 PM »
Any guesses on vintage and model? I'm think late 60's C5 with a later blade.
2006 WM LT28  2002 John Deere 990
Offline 47sawdust
Re: Another one saved from the scrapyard
« Reply #1 on: June 03, 2018, 04:07:40 PM »
Must be it's a Timberfarmer ;D
Mick
Offline mike_belben
  • Pulp Friction
« Reply #2 on: June 03, 2018, 06:33:55 PM »
What the heck is on back of it?
Revelation 3:20
Offline mjeselskis
    • Big Rock Lumber
« Reply #3 on: June 03, 2018, 07:44:45 PM »
Good question. It's set up like a crane and it pivots side to side on a truck hub. They even have it hooked into the hydraulics with a valve beside the seat. It's likely to get torched off.
Offline logman81
« Reply #4 on: June 03, 2018, 08:55:11 PM »
I would say c4 or c5 mid to late 60's i see it has timberjack axles.
Precision Firewood & Logging
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #5 on: June 04, 2018, 05:11:09 AM »
That's a great find! I would say it started life as a C5 and there seems to be some modifications since then :D, I don't think it came with the hour meter steering!
Offline Puffergas
    • Puffergas
« Reply #6 on: June 04, 2018, 01:22:07 PM »
Wow ! ! ! ! ! ! ! !
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline mjeselskis
    • Big Rock Lumber
« Reply #7 on: June 04, 2018, 06:32:59 PM »
Any ideas what the axles are? Only one has the timberjack planetary cover. Looks like at least one needs a wheel seal.
« Reply #8 on: June 04, 2018, 08:06:58 PM »
They are Rockwell axles, same as in the Timberjack 217,225,230's. I'm not sure of the actual number of it but I'm sure that someone on here knows it and will say. ;)
Offline mjeselskis
    • Big Rock Lumber
« Reply #9 on: June 04, 2018, 08:55:14 PM »
Thanks, they may be the same as the Rockwell axles in the other c4i had but I thought I remembered that there were weaker and stronger versions.
« Reply #10 on: June 06, 2018, 05:03:32 AM »
As a rule if the hub has eight wheel nuts that is the weakest ones, the hubs with twelve nuts are beefier.
Offline Neilo
« Reply #11 on: June 07, 2018, 12:38:13 PM »
Going off the look of the axles, Rockwell PR75 will get you close, except maybe the actual case and shafts which might be different length.
C5D tree farmer
Started by pigpen on Forestry and Logging
Last post June 17, 2012, 06:08:18 AM
by jftimber
c5 tree farmer
Started by MEloggah on Forestry and Logging
Last post March 18, 2013, 04:13:56 PM
by MEloggah
Tree farmer c4c
Started by deghan2172 on Forestry and Logging
Last post April 02, 2017, 08:52:41 AM
by bushmechanic
C4B tree farmer
Started by moose62 on Forestry and Logging
Last post May 18, 2013, 01:34:07 AM
by moose62
