Baltic Abrasives Technologies
Author Topic: Ballast box/skidder/trailer hitch  (Read 639 times)
Offline firefighter ontheside
  • I like trees.
« on: June 05, 2018, 07:47:59 PM »
I need to make a ballast for the three point of my tractor, but I also want to be able to hook up and skid logs with it at the same time and I also want to be able to have a receiver hitch on it that I can use to move my trailer around.  The problem I see is that the box will block the view of the hitch.  I知 used to being able to see it and pick up the trailer without getting off the tractor.  Anybody build anything like I知 talking about?
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline Puffergas
    • Puffergas
Re: Ballast box/skidder/trailer hitch
« Reply #1 on: June 05, 2018, 08:04:04 PM »
Can you split the box in order to see the hitch between the left and right box?
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
  • I like trees.
« Reply #2 on: June 05, 2018, 08:18:44 PM »
I saw a picture of one something like that.  That could work.  I知 also thinking of tipping on an angle so that I can see.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline celliott
« Reply #3 on: June 06, 2018, 05:36:34 AM »
Does your tractor have a loader? We have a plate that mounts to forks and we move trailers and hay wagons around with a skid steer from the front. Easy to attach/take off. Just a thought.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline jdonovan
« Reply #4 on: June 06, 2018, 06:27:40 AM »
sounds like you're trying to duplicate the wallenstein fxp skidding plate
  • I like trees.
« Reply #5 on: June 06, 2018, 07:18:24 AM »
C Elliott, that痴 something I hadn稚 thought of.  Maybe I should move trailers around that way.  Won稚 have to look over my shoulder.  I would still like the hitch on my ballast too, but it would be so important to have it visible.
I知 not sure, J Donovan, but I値l check out the wallenstein.  Thanks.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
  • I like trees.
« Reply #6 on: June 06, 2018, 01:10:28 PM »
I just made an appointment to get the tires fluid filled and then I値l see what more I want to do after that.  I have some weights on my current skidder attachment.  Maybe I値l add some more weight and be happy with that.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Offline thecfarm
« Reply #7 on: June 06, 2018, 02:00:37 PM »
No idea what you are doing with your tractor,besides skidding logs.
I have a 40 hp tractor and I skid logs and haul rocks and dirt with it. Loaded tires work good. I feel you need the weight low,in the tires and under you. Not 4 feet behind you and up in the air 2 feet.
Wife has a 30 hp tractor that we mow with,no loader. Loaded tires on that too.
  • I like trees.
« Reply #8 on: June 06, 2018, 02:12:54 PM »
Hey Cfarm, I want to do my share of lifting logs with the loader as well.  The weight hanging behind the rear wheels takes some weight off of the front wheels and so reduces stress of big logs.  I don稚 intend to carry them far though, so I may find I知 happy with just the tires filled and a small amount of weight off the back.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Help identifing trailer hitch
Started by FarmingSawyer on Sawmills and Milling
Last post November 30, 2014, 07:27:31 AM
by FarmingSawyer
Trailer hitch cover question
Started by Jim_Rogers on General Board
Last post September 08, 2012, 06:53:05 PM
by Jim_Rogers
Has anyone made removable hitch for WM trailer?
Started by flatrock58 on Sawmills and Milling
Last post September 21, 2014, 02:16:09 PM
by flatrock58
How to free a rusted trailer hitch ??
Started by chainsaw_louie on General Board
Last post September 28, 2006, 08:49:10 PM
by JimBuis
