Author Topic: HYDRAULIC Pump  (Read 1523 times)
Offline Caseybow123
  • Still hand fallin
HYDRAULIC Pump
« on: June 06, 2018, 05:00:43 PM »
Does anyone out there know where I can find a hydraulic pump for a Hough 30B loader? Cessna pump- 27 gpm.
Loader has the gas 6 cylinder International engine.
Offline Satamax
Re: HYDRAULIC Pump
« Reply #1 on: June 06, 2018, 05:55:59 PM »
There is a timberjack cesna pump on leboncoin.fr .  it's funny that i have bumped into it. If it's the right one. At least there is one for sale in the world.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline pineywoods
Re: HYDRAULIC Pump
« Reply #2 on: June 06, 2018, 07:56:49 PM »
You might try surpluscenter.com. They sometimes have cessna pumps
Offline Autocar
Re: HYDRAULIC Pump
« Reply #3 on: June 06, 2018, 08:01:32 PM »
I will second Pineywoods good place to start !
Bill
Offline mike_belben
  • Pulp Friction
Re: HYDRAULIC Pump
« Reply #4 on: June 06, 2018, 11:34:45 PM »
Does the pump have a data plate or any numbers in the casting?
Have you torn the pump down to verify that its bad and cant be refurbed inhouse or locally?
Revelation 3:20
Offline Riwaka
Re: HYDRAULIC Pump
« Reply #5 on: June 07, 2018, 06:50:50 AM »
Cessna Fluid Power Division (FPD) was started after WW2. In 1988 Cessna sold the fluid power division to Eaton Corp.
As above ascertain that it is the pump that is the issue and not the valve bank etc.
So you might be looking for the people who do a good job of remaning cessna and eaton pumps & compare costwise with other sources or adapting another pump etc.
Offline Caseybow123
  • Still hand fallin
Re: HYDRAULIC Pump
« Reply #6 on: June 07, 2018, 10:58:25 AM »
It is definitely the pump, not a spline left on the shaft. Surplus center doesn't have one. Pump number is 24600-31C
Offline mike_belben
  • Pulp Friction
Re: HYDRAULIC Pump
« Reply #7 on: June 07, 2018, 03:33:19 PM »
Google brought this vendor up for me
CESSNA 24600 HYDRAULIC PUMP | Cessna Hydraulic Pumps
Revelation 3:20
Offline Satamax
Re: HYDRAULIC Pump
« Reply #8 on: June 07, 2018, 05:13:02 PM »
Caseybow, i was talking gibberish, the guy in france is looking for one. Talk about being brain dead! And it's my mother tongue.
Offline Caseybow123
  • Still hand fallin
Re: HYDRAULIC Pump
« Reply #9 on: June 07, 2018, 10:16:09 PM »
Surplus center never had any. I need to find a good machinist to make me some splines. Like to find a backup though because I know this pump is weak.
Offline mike_belben
  • Pulp Friction
Re: HYDRAULIC Pump
« Reply #10 on: June 07, 2018, 10:53:01 PM »
Did it have a coupler or direct engage into a female shaft?   Did that get wallowed out?
Revelation 3:20
Offline Caseybow123
  • Still hand fallin
Re: HYDRAULIC Pump
« Reply #11 on: June 07, 2018, 11:22:22 PM »
Direct into female. It doesn't feel too bad, but I can't see inside so I pray for the best that new splines will work. I think the female splines are stronger material, at least I hope they are.
Offline Riwaka
Re: HYDRAULIC Pump
« Reply #12 on: June 07, 2018, 11:33:55 PM »
Hydraulic pumps might have some type of common mounting spec (bolt pattern and shaft diameter, spline count, shaft length etc, , check to see which combo yours might be.
Hydra Mount
NFPA Mounting Flanges and Shafts for Hydraulic Pumps and Motors - Womack Machine Supply Company
appear to have a few.
Cessna Hydraulic Pump | Cessna Pumps | Northern Hydraulics
Splines need taking care of. Not every machinist is likely to be able to repair those back to a reliable condition.
Lubrication of Spline Shafts Datasheet
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: HYDRAULIC Pump
« Reply #13 on: June 09, 2018, 09:51:19 AM »
It doesn't have to be a Cessna.  My old Tree Farmer forwarder came with one.  When it failed it was cheaper to get a new pump than have it rebuilt.  I replaced it with a Prince pump of the same specs from Surplus Center.  Figure out your RPMs, GPMs, mounting pattern, shaft size and spline or key, and adapters needed to plumb it.  I did the same thing on the steering/blade pump on my 132 Franklin forwarder.  It had a Hydreco pump.  Again I was able to match a Prince from Surplus Center.
Offline Corley5
    • Whittaker Farms
Re: HYDRAULIC Pump
« Reply #14 on: June 09, 2018, 09:53:55 AM »
Surplus Center has online references/calculators to help figure everything out.
Offline Corley5
    • Whittaker Farms
Re: HYDRAULIC Pump
« Reply #15 on: June 09, 2018, 10:02:03 AM »
You'll have way more into trying to fix that old pump than the cost a compatible replacement.  A reputable hydraulic/machine shop will tell you that.  That's a common spline/shaft and an SAE mounting pattern for the pump.  The female ends of the spline will need to be replaced too.  If you don't you'll have accelerated wear and will be back to square one shortly.
Offline Corley5
    • Whittaker Farms
Re: HYDRAULIC Pump
« Reply #16 on: June 09, 2018, 10:57:52 AM »
If that's not a standard mounting pattern now would be a good time to change to one.  That would solve availability issues in the future.   Standard mounts for motors and pumps is NFPA not SAE.
Offline Caseybow123
  • Still hand fallin
Re: HYDRAULIC Pump
« Reply #17 on: June 13, 2018, 02:20:49 PM »
Okay, so I managed to find a company to match up a pump. I can even use the same mounting flange.
Now, has anyone had experience in removing the female spline coupler? It runs off the crank but not sure how it is attached. Any ideas??
Thanks for everything so far.
Output of the hydraulic pump and engine HP to drive a full hydraulic Bandmill?
Started by R. Smith on Sawmills and Milling
Last post September 04, 2009, 08:31:01 AM
by Chico
Hydraulic Pump
Started by never finished on General Board
Last post October 06, 2014, 03:16:54 PM
by never finished
ID this hydraulic pump
Started by mjeselskis on Forestry and Logging
Last post October 04, 2013, 06:58:38 AM
by DDDfarmer
tw5 hydraulic pump
Started by OH logger on Firewood and Wood Heating
Last post June 05, 2016, 05:34:06 AM
by Al_Smith
