Baltic Abrasives Technologies
Author Topic: Gearmatic 19 on crawler  (Read 374 times)
Offline Jwinter7258
« on: June 07, 2018, 06:31:42 PM »
Ive got a Gearmatic 19 on a td7e crawler. Drum reels in when tractor is moving in forward and reverse. Handle is in hold position. Anybody in the Ct area familiar with these winches? Id pay someone to come out and fix it. If easier call me at 860-798-4039  Thanks
Offline longtime lurker
Re: Gearmatic 19 on crawler
« Reply #1 on: June 08, 2018, 06:55:10 AM »
thats usually related to the clutch band settings.
Its a gearmatic... bleed it welll, then bleed it again. they are difficult to bleed.
If was parked up a while go find something really big and burn any moisture out by trying to tow the untowable... put a line on a good solid tree, and go for a walk to the end of the cable, then winch her back in a few times with your blade dragging in the dirt. You should be able to free it up that wy
If not you might have to open the cover and reset the bands, or they could be full of brake fluid from a leak. The manual for the winch is available online as a pdf from allied systems.
Offline coxy
« Reply #2 on: June 08, 2018, 07:05:46 PM »
where in ct are you
Is 90 HP to much HP for a jd 450 Crawler ?
Started by g_man on Forestry and Logging
Last post February 23, 2011, 09:41:39 PM
by Bobus2003
JD MC Crawler
Started by moonhill on Forestry and Logging
Last post January 16, 2010, 12:36:49 PM
by captain_crunch
Sorry Crawler GLOAT.
Started by Ironwood on Urban and Community Forestry
Last post May 12, 2010, 10:42:48 PM
by Ironwood
Oliver oc3 crawler
Started by Firewoodjoe on Forestry and Logging
Last post November 23, 2014, 12:17:03 PM
by Firewoodjoe
