Author Topic: Timberjack steering ram  (Read 1015 times)
Offline jd540b
« on: June 07, 2018, 06:38:36 PM »
Wondering if I can leave cylinder in machine and just unbolt/remove gland with rod and packing to repack it.  Seems easier than digging whole thing out.  Anyone have luck doing it that way??  Itís a 240a
Offline Maine logger88
  • Don't force it get a bigger hammer
Re: Timberjack steering ram
« Reply #1 on: June 07, 2018, 10:40:39 PM »
I have done it before on my 225 never tried it on my 240 but I donít believe it is much different
Offline CX3
« Reply #2 on: June 07, 2018, 10:49:42 PM »
I know it can be done on a 380 as well. Go for it
John 3:16
You Better Believe It!
Offline Mountain_d
« Reply #3 on: June 09, 2018, 09:27:40 AM »
Let us know how you make out. A few pictures of the inside of the cylinder would be nice. I need to do the same and I am not sure how hard it is to get it back together? I thought one needed a press but I guess not if it can be done with the cylinder on the machine?
Mountain.
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Offline teakwood
  • Switzerland
« Reply #4 on: June 09, 2018, 10:37:27 AM »
I don't think that you need a press for a cylinder assembly/ disassembly. sometimes they're hard to get apart because of the old seals. What i most find challenging is the nut or security devices on the cylinderpiston (the head on the rods end where the seals go, i can't remember the correct word in english), they are sometimes a pain to open
« Reply #5 on: June 09, 2018, 06:37:38 PM »
No press but a long bar to put though the hole on the cylinder and a 3/4 drive impact will do it on the tj skidder. Teakwood gland is the word you are looking for I believe
Offline mike_belben
  • Pulp Friction
« Reply #6 on: June 09, 2018, 11:05:28 PM »
Yeah. Gland nut.
Revelation 3:20
Offline Mountain_d
« Reply #7 on: June 10, 2018, 06:23:43 AM »
Ok. Thanks for the info, folks. I am a little less shy to start the job now.
Mountain.
Offline dustyhat
« Reply #8 on: June 11, 2018, 07:02:30 PM »
Did it just a while back on a 225 ,like was said the 240 should be just as easy. the retaining ring that held it all in the tube was the hardiest thing for me .
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
« Reply #9 on: June 11, 2018, 07:32:47 PM »
Yeah that ring can be miserable sometimes.
Offline jd540b
« Reply #10 on: July 25, 2018, 08:41:34 PM »
Got Ďer done today. Ended up yanking whole ram out.  Could not see well enough in machine to get the snap ring out-decided to go deep and pull whole thing guts, feathers and all.  Good thing because one hose was pretty worn.  Once out repacking is piece of cake.  Took 45 min and good as new.  I think getting new packings into cylinder in the machine would be pretty tough.  I may be singing a different tune putting it back in but so be it.
Differential Steering
Started by Scott on Forestry and Logging
Last post March 07, 2003, 09:05:00 PM
by Mark M
Jd 440 Steering problem
Started by mackaylake on Forestry and Logging
Last post April 09, 2014, 09:58:52 PM
by Old Iron nut
Steering problem
Started by loggerman1959 on Forestry and Logging
Last post October 25, 2016, 08:40:59 PM
by loggerman1959
skidder steering question
Started by rick f on Forestry and Logging
Last post November 12, 2010, 05:46:40 PM
by vtlogger1973
