Author Topic: Which sprocket for 372xp?  (Read 1441 times)
Offline mike_belben
  • Pulp Friction
« on: June 08, 2018, 12:36:22 PM »
ive just done a crankcase swap on a 372xp that i bought in a slightly crushed state years back and revived. It runs great and is only missing the clutch and sprocket system.  My primary firewood saw finally scored the jug and i need to put this one into service.. Ive never had a 372.  Itll wear a 24" bar and cut hardwood up to 30" on the stump and ground.
What sprocket.. 7, 8 or 9?  3/8 pitch.  Jug is stock, carb limits are clipped and ill add another muffler port pretty soon.
Revelation 3:20
Offline sablatnic
Re: Which sprocket for 372xp?
« Reply #1 on: June 08, 2018, 04:10:11 PM »
3/8 pitch 7t.
And good luck with a great saw!
Offline Southside
« Reply #2 on: June 08, 2018, 04:14:12 PM »
Mine wears a 24" bar with a 7 tooth sprocket - never misses a beat, love the thing.  Last year I went to square chisel skip chain mostly because I found some cheaper - best move I made, took an awesome saw and made it even better.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: June 08, 2018, 04:24:24 PM »
No kidding.. I expected to hear 8 or 9.. Think my 395 wears a 9.. Will hafta look.
Is there just not enough torque to dog in with the 8?
Revelation 3:20
Offline Southside
« Reply #4 on: June 08, 2018, 04:41:09 PM »
I suspect she has the torque, might be more to do with the sweet spot and how high she likes to rev - just my guess.  Runs nothing like my old 660 used to, that had a lower sweet spot.
Offline Gearbox
« Reply #5 on: June 08, 2018, 08:42:24 PM »
I just put a 8 on a 2075 . Haven't had it on the processer yet so we will see what that extra tooth does . 2075 turns way less RPM's than a 372 .
Offline ehp
  • logger/chainsaw hack
« Reply #6 on: June 08, 2018, 10:35:45 PM »
7 tooth, lots of guys run a 8 tooth but if your chain is cutting and in normal bigger hardwood the 7 tooth is faster and less strain on the motor
Offline mike_belben
  • Pulp Friction
« Reply #7 on: June 08, 2018, 11:18:21 PM »
Welp, i guess ill order the 7 then.  Thanks boys.
Revelation 3:20
Offline ButchC
« Reply #8 on: June 09, 2018, 07:49:44 AM »
An 8 tooth is kinda fun if your running a 20" bar doing work that can be done with a 346 or 550 but for most work a 7 tooth is probably the best  choice. I have an 8 on my 576  but it would like a 7 when  using all of the 25" bar.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline mike_belben
  • Pulp Friction
« Reply #9 on: June 09, 2018, 09:39:02 AM »
I have a jar full of rim sprockets but it hasnt turned up yet since the move.  ordered a chinesium 7 kit last night.
Revelation 3:20
Offline teakwood
  • Switzerland
« Reply #10 on: June 09, 2018, 11:12:49 AM »
Totally agree with you ButchC
I have no experience with the 372, but for a 70cc saw i would also recommend a 7 tooth
Offline knuckledragger
« Reply #11 on: June 17, 2018, 07:58:40 PM »
Im in agreement with the responses. I run a "24 bar&chain on my 372xp with a 3/8 7 sprocket and I cant imagine using anything other than that. Im certain you will be pleased as well.
Offline Skeans1
« Reply #12 on: June 17, 2018, 09:30:40 PM »
Normally Ill run an 8 pin sprocket on the 372 with a 32 semi skip chisel if its setup right itll sing if its like factory youll need a 7.
Offline mike_belben
  • Pulp Friction
« Reply #13 on: June 21, 2018, 04:36:55 PM »
7pin came in.. I am officially in love with 372XP.  It is perfect.
Revelation 3:20
Offline hedgerow
« Reply #14 on: June 21, 2018, 05:25:47 PM »
I have a buddy with a 372 with a 7 pin and runs a 24 bar on it most of the time and it is a great running saw in hardwood like hedge and locust.
Offline Southside
« Reply #15 on: June 21, 2018, 06:55:28 PM »
There is something special about that saw for sure.
Offline mike_belben
  • Pulp Friction
« Reply #16 on: June 25, 2018, 11:38:08 PM »
Little tip that may help someone else.  The coil in this 372 quit today.. It was sorta smashed.  New oem is about $70 but the husky 350 and thus jonsered 2150/2152 etc swapped right on, i have a crate full of blown up 350s.  Crisis averted.
Revelation 3:20
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #17 on: June 27, 2018, 09:45:09 PM »
Yeah I believe there the same from a 340 up to a 390. Only difference is some are rev limiting and some are not. I think blue is limited and black is non limited
Offline mike_belben
  • Pulp Friction
« Reply #18 on: June 27, 2018, 11:21:59 PM »
I took a blue off and put a black on.
Did some searching and it looks like youre right.  Btw i did have to keep the 372 plug wire.
Revelation 3:20
Husqvarna 372xp Original Edition vs. 372xp Current Edition "X-Torq" Saws.
Started by weimedog on Chainsaws
Last post March 25, 2018, 04:00:48 AM
by knuckledragger
385 with 8 sprocket...
Started by Ever Green on Chainsaws
Last post March 26, 2006, 10:40:30 AM
by Rob
Rim Sprocket for MS 460
Started by Good Feller on Chainsaws
Last post July 28, 2008, 01:13:30 AM
by Southernlogger007
3/8 lo pro rim sprocket
Started by Caloren on Chainsaws
Last post June 22, 2015, 10:48:46 PM
by joe_indi
