Draw for handbuilt acoustic guitar get your name in
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Glue- Titebond, Quick and Thick  (Read 839 times)
Offline caveman
  • In the land of the blind the one eyed man is king
« on: June 12, 2018, 08:03:25 AM »
Yesterday, after doing some tractor work for my uncle, who is president of the local woodworkers club, he showed me a glue that I was previously unfamiliar with - Titebond Quick and Thick.  He spread a little on the end grain of two pieces of oak that were about 3/4"x1 1/2" x 1 1/2" and clamped them together for 10 minutes.  I tried to break the glue joint with my hands to no avail.  Thinking I might have been suffering from girly hand syndrome, I took a 1"x 3" and whacked it a few times while holding it in my left hand and did not break the glue joint.
He was given a few sample bottles of Tite Bond glues at the last woodworker meeting by the Tite Bond rep.  It may be a useful product for those glue joints you don't want to wait on.  It is listed for interior use.
Also, the rep mentioned that cutting boards glued up with Tite Bond III were okay to put in the dishwasher (not that I would ever put a wooden cutting board in a dishwasher).
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
Re: Glue- Titebond, Quick and Thick
« Reply #1 on: June 12, 2018, 08:17:34 AM »
Never seen it in the store, that'll will be handy in places for sure!
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline DPatton
« Reply #2 on: June 12, 2018, 08:42:56 AM »
I have seen it in the store but didn't know of its capabilities till now. Good to know.
Offline btulloh
« Reply #3 on: June 12, 2018, 04:28:43 PM »
Good info.  Sounds like it could be great for trim.
Have to try that end grain thing myself just to see what happens.
HM126
Offline Bruno of NH
« Reply #4 on: June 13, 2018, 07:46:23 AM »
As a finish carpenter for many years that would be very helpful while doing trim work.
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline 21incher
« Reply #5 on: June 13, 2018, 03:29:16 PM »
That looks like it would be great for picture frames. Thanks for sharing.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline caveman
« Reply #6 on: June 13, 2018, 06:43:54 PM »
I was thinking it would be good for picture frames too.
Caveman
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #7 on: June 13, 2018, 10:16:08 PM »
Thans for sharing this Caveman. New to me.
Where's the Spoon?
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #8 on: June 14, 2018, 08:36:40 AM »
What is the work up time?
I am slow and clumsy so need a lot of time before set up.
I remember as a kid there were samples of 1" wood dowels glued end grain in our local (long gone) store.
The proprietor challenged us to break them apart, but they were so short you couldnt get a decent purchase
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline logbyr
« Reply #9 on: June 14, 2018, 10:28:50 AM »
I think if they changed the name to titebond board stretching fluid they would find a huge untapped market.
Offline caveman
« Reply #10 on: June 25, 2018, 02:51:05 PM »
Update:
I asked my uncle to do another test of the quick and thick. He glued two 1"x4"x8" oak boards together on the end grains, clamped for 20 minutes.  He put a fulcrum on a bathroom scale after the 20 minutes had elapsed and he reported that the glue joint failed at 40 lbs of pressure as shown on the scale applied to the ends of the boards.
Next, he glued the same sized boards together in the same fashion and clamped for 24 hours.  He tried to break the joint with his hands and then over his knee but was unsuccessful at breaking the glue joint.  I don't guess he put pressure on the scale after the longer glue up.
Peter, I think the set time is relatively quick - like a minute or so.
Caveman
Offline Larry
« Reply #11 on: June 25, 2018, 08:22:49 PM »
I do some segmented wood turning.  To make the rings a board is cut into pie shaped pieces and glued back together.  Its all end grain gluing.  An example is this bowl.
The majority of the time I use Titebond Original.  I can glue a ring and put it on the lathe to be turned after 10 minutes but to be safe I normally wait 15-20 minutes.  And yes the end grain joint is not as strong as face grain.
One method I've used with glue ups is called the Rub Joint.  The joint with glue applied is rubbed together for 30 seconds to a minute.  At some point the joint will grab and can no longer be moved.  Trim carpenters use this method a lot.  Again standard Titebond Original.
I don't think I would pay a premium for the new glue unless it could do something I can't do with the standard glue.  Of course I would gladly test a free bottle of the new stuff. :)
Thick slab glue up
Started by stumpy on Drying and Processing
Last post January 02, 2012, 07:42:19 PM
by shelbycharger400
How do you glue up thick table tops?
Started by ozarkgem on General Woodworking
Last post June 03, 2015, 12:03:25 AM
by 5quarter
New Very Quick Setting Wood Glue
Started by DR_Buck on General Woodworking
Last post January 23, 2014, 03:16:16 PM
by Lud
Can you use calking glue to glue logs together?
Started by Rod on Timber Framing/Log construction
Last post February 28, 2005, 10:45:59 AM
by Rod
