Honeymoon Covered Bridge in Jacking NH
Started by Peter Drouin, July 26, 2018, 06:16:36 PM
Peter Drouin
Got a call from the state of NH to cut some beams for them to fix the bridge.
It was built in 1876. Some guy in a cement truck, Ya, a 10 wheeler.  ::)
thought he could go on it. Posted for 3-ton limit.
Built by Charles Austin Broughton and son.
They had a big dairy farm during the Civil War. He was a sergeant in the 18th regiment of the NH Company E.
This is a dream job for A&P Sawmill. The place to go to get lumber for all the covered bridge in NH.
8) 8) 8) 8) 8) 8) 8) 8)
A&P saw Mill LLC.
License NH softwood grader.
OffGrid973
Your Fellow Woodworker,
- Off Grid
I suppose hemlock will be used?
I googled it and I've been across that bridge a few times.
sprucebunny
Congratulations ! I live in that area and drove by the scene in Jackson right after it happened.
Pretty hard to believe. A 58 year old driver who had worked for the company 15 years. Just can't imagine what caused him to make that choice. There is a turn off the main road ( Route 16) about 60 feet from the bridge and there is another road to avoid the bridge 1/2 mile further north.
Lawg Dawg
AWESOME! CONGRATULATIONS! That should get you some (MORE) publicity! :)
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
Bruno of NH
I heard about it on the radio
Glad you got the job :)
sprucebunny
They just repaired the other end of that bridge about a month ago. A younger person was texting, hit the upright on one side and rolled the car.
caudlefarm
Does anybody have any pictures of the bridge. Just curious.
1997 cook ac36 sawmill. 96 lull 644b-37. 1995 international 4700. 1999 873F bobcat. 2 MS880 stihl. 2 064 stihl. MS261 stihl chainsaws
4x4American
Sounds like the cement truck driver is batting for A&P Sawmill.  Homerun too, nice!
Boy, back in my day..
PAmizerman
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
jason.weir
I'm sure there are lots of competent truck drivers out there, but the other 80% make them look bad.
Although I've never met a cement truck driver that had any fear of driving anywhere.
Some good pictures here
Jackson Covered Bridge struck again | Local News | conwaydailysun.com
-J
Peter Drouin
What I'm asked to do is resaw some Dug, fir that the DOT has in its inventory. I guess they have a bunch of it to fix bridges in the state.
Just a good chance to show what A&P sawmill can do for them.
We do have 50' of LT 40 supper under a roof.
Tomorow or Mon I have 50- 6"x12" Chestnut beams of different lengths coming up from Boston to be resawed 6/4 for the ceiling in high-end condos.
I'll put up some pics when I can. The jobs are by the hr plus blades.
A&P saw Mill LLC.
Brian_Rhoad
Here is a link to some pictures of the bridge.
Offsite picture link removed by Admin, refer to picture posting rules
Peter Drouin
They brought me a pice if D. fur to look at. It was some kind of pressure treated stuff that was in a vacuum then treated under pressure. I don't think I can cut it. It dulled the chainsaw in one cut.
[ A pice they cut off a beam to show me ]
They called back and are going with my hemlock if the engineers say it's ok.
There's a push to keep the bridge original.  A lot of it is Chestnut, But, there's no more of that around here.
Jeff, this page is wide, have to push it across the screen to read, Can you fix it?
A&P saw Mill LLC.
It was wide because someone posted a link to offsite images that is not allowed. Removal of the link should have fixed it.
Crossroads
Congratulations! That will be nest to have some of your beams in that old bridge
Crusarius
you going to brand any of the beams? could be great advertising :)
Peter Drouin
A&P saw Mill LLC.
Crusarius
Probably make the paper either way. and it is definitely kool to be part of history like that.
YellowHammer
Thats a really fun job and should be very good for business.  Sounds like a good subject for another local news article.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
UpInATree
Congratulations Peter!  I look forward to seeing your beams on the bridge.
Wood-mizer LT70HD D55 Wireless, Wood-Mizer ED-26, A whole bunch of Stihls. Alaskan Mill 74",  Bucket Truck, Log Truck, Chippers, trailers, dump trucks,   Kubota M9540, L3010D and B7510. Cord King.   Learning Timberframing under Jim Rogers
sprucebunny
Peter must be hard at it... we haven't heard from him in a while.
The bridge is waiting.
If you look carefully, you can see a sprinkler system.
Peter Drouin
Beam all cut, Will post some pixs later.
A&P saw Mill LLC.
petefrom bearswamp
 smiley_clapping smiley_clapping smiley_clapping smiley_clapping
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Peter Drouin
Cutting some 8"x8½"x 24' and 6x8x24'
Some 4"x4"x20'.
I'm working with Mr Normand Legere Superintendent of Bridge Maintenance
NHDOT.
Another bridge was hit somewhere a day or so ago He needs 20- 4"x6"x16'
Bad year for NH bridges.   :o
A&P saw Mill LLC.
