Author Topic: Has any built a generator using a Dodge Cummins diesel?  (Read 1154 times)
Offline WoodenHead
« on: September 13, 2013, 08:59:53 PM »
My father-in-law has a 92 Dodge Cummins diesel truck that basically has fallen apart.  The engine though is still strong after about 300,000 miles.  Has anyone ever attempted to use the Cummins engine for a diesel genset?  If so, what governor/control system did you use on it to keep the RPMs steady?
Offline sawguy21
Re: Has any built a generator using a Dodge Cummins diesel?
« Reply #1 on: September 13, 2013, 10:29:37 PM »
That would be an interesting project with a 4 pole 1800 rpm generator. I am unsure how a governor system would be hooked up and controlled.
Offline SPIKER
« Reply #2 on: September 13, 2013, 11:06:49 PM »
They are many places making them including Cummins themselves.   I used a lot from a company called "GENTEK" down south, LA or GA? cant remember now after a few years...   Good guys to work with.
Offline barbender
« Reply #3 on: September 14, 2013, 09:56:32 AM »
There should governors available for that engine, as it is also used in fixed rpm equipment applications.
Offline snowstorm
« Reply #4 on: September 18, 2013, 08:25:14 PM »
it has a variable speed gov. lets say you use a cable or what ever and set rpm at 1500 it will try its best to mantain 1500 rpm under load. if the load is to big you may loose some rpm
2002 Dodge Ram Cummins 4x4
Started by Corley5 on For Sale
Last post May 31, 2018, 11:04:01 AM
by Corley5
Dodge- Cummins 98- 01 Watch out for weak block
Started by Banjo picker on General Board
Last post June 28, 2017, 12:29:11 AM
by Chop Shop
2006 Dodge Cummins Heater Quit.
Started by LeeB on General Board
Last post October 27, 2018, 12:11:09 PM
by LeeB
Any comments on the Dodge 3/4 ton trucks with cummins 5.9l engine?
Started by oakiemac on General Board
Last post August 13, 2005, 10:29:44 AM
by Dakota
