How many bands
Started by Inwoodsman, September 08, 2014, 06:25:26 PM
scully
I try and get as many as I can ! I think I have about 40 now . Keep in mind certain bands for differant types of wood etc. It's like drill bits better to have a pile of em ! If you get a new mill start off with a new box of bands .....
I bleed orange  .
gimpy
Do any of you use a metal detector on your logs as a normal procedure?
I'm a new owner (used LT40) and haven't made any sawdust yet.
For those like myself, I will be sawing mostly pine. How long are my blades likely to last? I'm not going to be a member of the million BF club anytime soon but I will be trying to cut all my lumber for building my home, outbuildings, fences and such on my pine filled property.
Just got back from Woodmizer getting my mill checked out and will not be able to fire her up for about a week. But I have 2 boxes of (15) blades (actually 30 + 3 blades) and now I'm wondering if when I get going if I should have a few more boxes. Re-Sharp (with replacement) for me is about a week turn around.
How much pine can a woodmizer blade cut if a woodmizer can cut pine? (If you catch the reference)
Gimpy old man
Lucky to have a great wife
John Deere 210LE tractor w/Gannon Box
I expect 500 to 600 BF from a blade on my manual LT15.  You can get more BF per blade on a hydraulic mill with more HP.  The key is to only saw clean logs or run the debarker on the LT40 if it has one.
Chuck White
In White Pine, I usually saw around 800 bf before blade change, but consider anything over 500 bf satisfactory.
gimpy
If I understand this correctly, what we're talking about is as an example, a 14" small end by 14' length is 100bf.
So a blade will cut from 5 to 8 of this size logs. Now that is something I can understand.
Gimpy old man
backwoods sawyer
One or two saw per day
average twenty logs that size
or 2,000 bft a day
seems to be more when Little Jo is sawing as she puts me to log and lumber handling while she keeps the sawdust flowing ;)
Backwoods Custom Milling Inc.
gimpy
So you might go through 2-4 blades a day?
Just trying to be able to estimate me needs.
I appreciate the help. I'd love to meet Little Jo someday. I'd bet she and my bride would have some fun.
Gimpy old man
terrifictimbersllc
Trim off a half inch from the front end of a log when it looks dirty.  The gritty end of a dirty pine log (think "sandpaper")  can dull the blade before it ever enters the log. Debarker doesn't help with this.
YellowHammer
Gimpy,
Congrats on the new mill. 8)  Your burn rate on bands will be slightly higher in the beginning as you go up the learning curve and get a feel for the saw and sharp blades. Also, the inclination will be to run sweet cutting bands too long and get the most out of them, but that is very hard on them and really shortens their life.  On the other hand, every now and then a new or reshapened band will not perform well out of the box and the inclination will be to force and push it.  Other things like feeding too slow, pitch buildup, best blade lube/cleaner for the species you are milling will also take a little time to get dialed in.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
NCForester
I do portable custom sawing for people in Western NC.  I currently have about 300, with about 50-60 dull ones that will get sharpened when the weather turns bad.
backwoods sawyer
Thirty saws is a good number to start with and will cut a few piles of wood. Can alway add another box if you seem to be short on saws.
When you signed up for resharp did you opt for the keep full plan?
We will have to take you up on that cup of coffee next time we are in the area. Right now we are piling up the sawdust all around the willamette valley ;D
gimpy
Thank you for the help. Yes I opted for the keep full option. Will be getting my first delivery with one replacement in a few days.
Keep your blades moving.
Gimpy old man
