Building my mill...
Started by Kbeitz, April 17, 2015, 07:04:07 PM
Kbeitz
Learning as I go. I worked at Grizzly Tools in Muncy Pa. and I did some welding for them for my two bandsaw blade wheels. I pretty much had all the steel I needed execpt for a small chunk of 30mm round rod I needed for the bandsaw wheels. I'm not sure what engine I'm useing yet. I got my eye on one thats listed at an auction tommorow. My carrage is going to be motor driven. I got room for a 30" log 18 feet long on the mill. I have my own machine and weld shop. I also have a woodwork shop and thats why I want a mill. Right now I'm tired of welding... I think I'll take a few days off.
Love machine shop work
and Wood work shop work
And now a saw mill work
gww
Thanks for posting and I am hoping for more pictures as you go.
Good luck
gww
Kbeitz
Working on it every day...
 [img]
Kbeitz
What sawmill? I'm too busy looking at the wall with the wheels on it and as my wife would say,all the other junk.  :D Looks like my place.  ;D
Ga Mtn Man
That's a lot of progress for someone who was going to "take a few days off".  Too bad you had to ruin it with all that new steel  :laugh:.
It appears that your sawhead is suspended by the winch cable through the pulleys at the top of the masts.  I think you may have trouble keeping the sawhead perfectly parallel to the bunks as you crank it up/down.  But then again, I've never built a bandmill so what do I know. :)
Kbeitz
All the steel was used... I just cleaned it up....
I got real lucky today at an auction.
I got the 13 hp Honda engine that I wanted for the mill for $150.00
Then  bid on what looked like a real of bandsaw blade band...
I was going to try to make my own blades but cutting the lenght I need and silversolder it together.
I won that bid for $15.00.
After I got it home and opened it up I found it was already made in to 153" blades.There was 7 of them and they fit my saw. Now whats the chances of that...
On Wednesday when I checked everything out the bandsaw blades had no rust.
So they are a whole lot better than they look.
Kbeitz
Posting pictures here sure is tough...
For the best of me I could not get it to show two pictures..
And then 2 min later it shows up... Hummm...
Kbeitz
With all the weight on the cables I dont think it's going to move.
I bet there is around 200 lbs at least on the masts.
ozarkgem
Were the band wheels from a Grizzly saw? If so what model? Are you using 1 1/4 width blades? Looking good on the build.
arnold113
Kbeitz, Keep up the great work. Looks like you're having a lot of fun. It gives a person a feeling of satisfaction to build something rather than buying it ready made. I'm just finishing up my band mill that I've built mostly out of repurposed steel.
Seeing as you have built a lot of things, you know what I'm talking about.  Good luck on all your foraging.
Arnold113
DIY band saw mill: four post, 25 HP gas engine, 32" x 18' portable, 24 vdc and hydraulic controls, pineywoods log turner, hyd log loader. RF remote controls for mill.  DIY set works.
Kbeitz
Quote from: ozarkgem on April 18, 2015, 08:16:53 PM
Yep off the model  #G0701 5 hp Industral bandsaw. Im useing both 1-1/2 and the 1-1/4" blades.
downsouth
Looks good!
All those bands need is a few squirts of wd40 or ATF and they are good to go. Good luck and keep us posted
Ocklawahaboy
Much better than I could ever do.  I'm curious about your log loading plans.  If you use ramps, it looks like those fenders would get in the way.
Kbeitz
Quote from: Ocklawahaboy on April 19, 2015, 01:02:13 AM
I'm hoping to make my ramp curved.
Or I see some builders make there fenders removable.
They kinda slide on place using square tubbing.
I also thought about making a log lifter...
All this will take another dream night to process.
Here is a picture of my Tension adjuster.
ozarkgem
I should have asked in the previous post. What is the diameter and width of the wheels?
Any idea what the cost is from Grizzly on the wheels?
Jim
Kbeitz
Quote from: ozarkgem on April 19, 2015, 07:37:39 AM
Jim
17 inch across OD.
2" width on the rim and 6" at the bearing housing.
I was told around $600.00 each. (ouch)...
Kbeitz
I made a bandsaw blade clamp and repaired my first blade today.
I'm happy with the way it turned out...
I need to take a better picture of the weld job.
This picture makes it look bad...
Repaired with silversolder.
Kbeitz
Made the engine plate today and I got it welded to the carrage and the engine bolted fast... Break time....
Well yes you did, and in fine style!!   :o   :)
Kbeitz
I got my Cooks bandsaw blade roller guides in today...
I would have tried to make these but the time is would take I thought I would just buy them. Also they are hardened. I have a heat treating oven but I would probably use enough electric hardening the rollers in dollars as the boughten one cost me.
Hilltop366
Ocklawahaboy
Quote from: Kbeitz on April 20, 2015, 11:31:35 AM
That is similar to the way some of us with mills still buy 2x4s.
Kbeitz
bandmiller2
"K"  copy the bearing numbers down and have some spares. After long use those guides will wear and need to be trued up, easiest is to have a tool post grinder on your metal lathe if not anneal and turn. I made a heavy duty tool post grinder for my lathe used a heavy grinder with a 6" wheel made a bracket to hold it on the tool post, just what the Dr. ordered for hardened pieces. Frank C.
