Vertical Upright Trick
Started by Percy, September 05, 2017, 08:56:15 PM
Percy
I'm sure there has been many variations of this before but when I learned this on my LT40, it didnt work nearly as well as the 70. Whenever I have a thick wide flitch that needs edging on the mill and I dont wanna gouge it up forcing it vertical with the clamp, I do this. It works very well. If the curve of the live edge is not favorable for sliding over the uprights, I use the toe boards. Sometimes I have to use the cam bearing housing to keep the flitch from getting too crooked. Helps when they are centered.
https://www.youtube.com/watch?v=fD0sxv5DWtk
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Dan_Shade
I use that trick every time I trim flitches.
I have had a stack of boards fall off the back, though... That kills any productivity gained.
I do wonder if doing that impacts the alignment of the uprights, but I use that trick anyways.
I lift up the stack with the toe rollers, and inch it over the back stops....
lots of dull bands and chains
YellowHammer
If you use the same "reverse roll" on a cant, you can flip the slab or flitch onto the loader arms without having to do it by hand.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Chuck White
Used that a few times myself!
It's a little more touchy with the old "flipper" clamp!
Percy
Quote from: Dan_Shade on September 05, 2017, 09:24:48 PM
I have an edger so I dont have to do stacks...That must be cool when it works out. Just the 4x16 stuff thats so hard to get upright by conventional means. My uprights take a beating, specially when turning a big cant or log.
Quote from: YellowHammer on September 05, 2017, 10:49:22 PM
I learned that one by accident....heh
Quote from: Chuck White on September 06, 2017, 07:12:38 AM
Ya!! My old 40 had the "flipper'. The two plane clamp has spoiled me. You develope some skills with that "flipper".
