old homelite RPM
Started by chugbug, June 14, 2008, 09:02:31 PM
chugbug
Does anyone know about where my old Homelite VI955 should be running at , I'm guessing this saw is about 25 years old and fairly big size wise but not sure of HP or C.I.  I'd like to set the hi speed mixture with a tach and see how it runs , is this the prefered way of adjusting saws or is setting by ear still the best??
oldsaw
I set them by "burble".  First do the low speed jet, then set the idle, then richen up the high speed until you get a bit of burble at WOT.  Check the transition between the low speed and high, and you are done.
So many trees, so little money, even less time.
Stihl 066, Husky 262, Husky 350 (warmed over), Homelite Super XL, Homelite 150A
mburrow
the VI955 is 5.01 ci and if I remember right wot is around 7500 rpm
Urbicide
From Mike Acres site, Chainsaw Collector's Corner.
Model: VI-955
MANUFACTURED BY:  HOMELITE CORPORATION
  PORT CHESTER, NEW YORK, U.S.A.
SERIES OR ASSEMBLY NUMBER:
YEAR INTRODUCED:
YEAR DISCONTINUED:  1977
ENGINE DISPLACEMENT:  5.01 cu. in. (82.1 cc)
NUMBER OF CYLINDERS:  1
CYLINDER BORE:  2.0625 in. (52.3 mm)
PISTON STROKE:  1.5 in. (38 mm)
CYLINDER TYPE:  Aluminum with chrome plated bore
INTAKE METHOD:  4 reed pyramid type
MANUFACTURER ADVERTISED H.P.:  not advertised
WEIGHT :  14.5 lbs. (6.5 kg) powerhead only
OPERATOR CONFIGURATION:  One Man operation
HANDLEBAR SYSTEM:  Rigid
CHAIN BRAKE:  none
CLUTCH:  Centrifugal
DRIVE TYPE:  Direct
CONSTRUCTION:  Die cast magnesium
MAGNETO TYPE:  Capacitor Discharge electronic
CARBURETOR:  Tillotson HS-151A
MAJOR REPAIR KIT:  RK-23HS
MINOR REPAIR KIT:  DG-5HS/T
AIR FILTER SYSTEM:  Cellulose fiber element
STARTER TYPE:  Homelite automatic rewind
OIL PUMP:  Automatic with manual override
OPERATING RPM:  7,500
IGNITION TIMING:  Fixed
BREAKER POINT SETTING:  none
FLYWHEEL/COIL AIR GAP:  .005 to .007 in. (0.12 to 0.17 mm)
SPARK PLUG TYPE:  Champion CJ-6
SPARK PLUG GAP:  0.025 in. (0.63 mm)
CRANKSHAFT MAIN BEARINGS:  Ball on mag end, caged needle roller on clutch end
FUEL TANK CAPACITY:  35 fl. oz. (1035 ml)
FUEL OIL RATIO:  32:1
RECOMMENDED FUEL OCTANE:  Regular grade
MIX OIL SPECIFICATION:  Homelite Chain Saw mix oil
CHAIN PITCH:  3/8 in.
CHAIN TYPE:  Oregon 72D
BAR MOUNT PATTERN:  14 link
SHORTEST GUIDE BAR SUPPLIED:  16 in. (40 cm)
LONGEST GUIDE BAR SUPPLIED:  36 in. (91 cm)
COLOUR SCHEME:
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
COMMENTS:
chugbug
WOW , Alot of info there Urbicide , I really appreciate that , I wasn't sure of any of the specs for that saw , I bought it  so long ago !!!
