Lumber storage situation.
Started by Dave Shepard, February 23, 2018, 08:24:16 PM
Dave Shepard
I have access to a building where I can potentially store some lumber, as well as set up a woodworking and timber framing shop. There is a lot of development work to be done initially, there's an Olympic sized pool in the timber framing shop, but for starters there is a lot of dry storage. My question is how dry does lumber have to be before I can move it inside (still stickered)? Cherry would probably be what I'm most interested in storing, as well as white pine. There is no air flow, and no electricity, as there is a $6,000.00 deposit required to turn on the 250kw service. In the future, I'd like to have a kiln at this location, but not until there is power.  Thanks.
Southside
What are your plans for the pool?  Must be a massive building for sure.
White Oak Meadows
Dave Shepard
Pool room is 36x80. Fill it in and use it as a timber framing shop.
longtime lurker
+1
My exact first thought was "woo hoo! Sawdust bunker".
Don P
Borate dip tank
You should be safe below fiber saturation ~25%, no free moisture to support fungi. The building supplies keeps 19% in dead storage.
How's the roof? Old leaky flat roof= money pit.
Dave Shepard
YellowHammer
Is the building an old YMCA or something?  Sounds very interesting.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Dave Shepard
Former reform school. Now full of chickens. But not this building.
Don P
