Slabbed the crotch log today (pictures)
Started by Troy, February 10, 2006, 07:42:18 PM
Troy
Since bad weather is on the way I took the afternoon off and came home to get that crotch log slabbed.  Below is a picture of the first slab off.  I got it all cut up.  Only two pieces will probably hold together as the inclusion got pretty bad towards the middle.  Several of the halves that did separate looked very nice.  I found that it is a very slow process.  One cut would take anywhere from ten to fifteen minutes.  on the next to the last cut I saw something shinny through the sawdust on top of the log.  Looks like I cut right through the middle of two coper coated slugs.
Peterson ATS 8" 27hp
Dan_Shade
it takes that long per cut?  how often are you sharpening the chain?
I'm sure it will go faster than that, i can do a 36" cut in red oak 8' long in about 10 minutes with my 066.
nice though, metal wrecks havok on a saw chain
lots of dull bands and chains
Paul_H
[lmg width=300 height=400]https://forestryforum.com/gallery//userpics/12935/RedSlab08.jpg[/lmg]  [lmg width=400 height=300]https://forestryforum.com/gallery/albums/userpics/12935/Slugs.jpg[/lmg
Troy,
when you post pics,please take care that you don't paste consecutive links on one line.Instead,hit enter a couple of times before pasting the next link.
The example above put the pictures side by side which stretched the page out.
The example below is the corrected version.
[lmg width=300 height=400]https://forestryforum.com/gallery/albums/userpics/12935/RedSlab08.jpg[/lmg]
[lmg width=400 height=300]https://forestryforum.com/gallery/albums/userpics/12935/Slugs.jpg[/lmg]
Really nice pictures by the way!
iain
Nice going, bet your glad you took a day off to do some real work :D
iain
getoverit
Troy, did you go with the Peterson slabber or did you make one yourself?
Troy
jpgreen
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
Troy
