ford tractors
Started by JAMES G, August 18, 2007, 09:23:40 PM
JAMES G
has any one ever worked on ford 801 powermasters. Have to rebuild a diesel engine and need to make sure I have the correct info.Where the serial number is has been eaten away from rust and battery acid thru the years.
dutchman
I have the Ford service manual for 1955-1960.
Operate 821 gas and 841 diesel loader and hoe.
If you need specs e-mail.
JAMES G
thanks dutchman I was able to get of a more learned feller than myself on the subject and was told I had a 801 ford powermaster model 841.I have the manual, so many thanks to you anyway.
