Blade degree
Started by moandrich, December 02, 2012, 07:54:09 PM
moandrich
We were looking at blades we sent in to be sharpened.  Cant tell the difference between 4 and 10 degrees. any pointers
woodmizer lt 40HD  2007
Kubota RTVX1100 2019
Kubota L3940   2009
You should be able to tell the differance looking at boath side by side,4 degree is almost perpendicular wile the 10 you will detect considerable hook. Frank C.
John Bartley
I sharpen my own, but .... I set up the grinder using one of these : http://www.busybeetools.com/products/PROTRACTOR-MACHINIST-M024.html and I also use it to check blades that I sharpen for others.
John
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Chuck White
I've never paid much attention to the hook (or angle), but I sort of assume that the lower the angle, the closer to 90° the back edge of the blade and the face of the tooth become.
In other words, if the hook was 0°, the face of the tooth would be 90° to the back edge of the blade!
jcbrotz
Depth/shape of the gullet is the biggest difference on these blades, I got myself one of the new blade angle guages from woodmizer after my last sharping shipment.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
ladylake
If the back of the wheel get rounded too much it is hard too tell the hook angle as it starts to curve near the tip of the tooth. Softer wheels need to be profiled often to keep the face of the tooth looking like a new blade. 4* blades cut hard woods straighter than 10* blades do, it's the hook angle that matters not the gullet as when I sharpen my new 10* blades at 4* the gullet is real close.  Steve
Papa1stuff
WM has a great little tool to check for all the different degree blades! ;D
And it is does not cost too much!
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
terrifictimbersllc
Last time I asked, they weren't selling that blade guide any more.  I've learned to tell the difference easily between 10's and 9's, and if I have a 4 or 7 that is out of its box I put a colored tie strap on it.
pnyberg
There was an add ad for the blade gauge somewhere not too long ago (WoodMizer Way?).  I ordered one in October.  Part #065691.  Cost $15.00.  I just checked, and this part # still works in the online parts store.
--Peter
No longer milling
drobertson
Not sure how many  blades you have on hand, but I would say just start sawing, they all will cut for sure.  david
moandrich
WM number worked, ordering a guide now, thanx.
Kubota L3940   2009
