Tanaka 33cc top handle saw
Started by DelawhereJoe, March 29, 2018, 02:10:42 PM
DelawhereJoe
Do any of you guys one or have the Hitachi copy of it ? If you do or have used one can you please give me your experience with it.
Gary Davis
don't have that on but I do have the sthl ms 150 tc  top handle weighs about 5.7  lbs loop on one end to tie a rope to  ,I can run it one handed with either hand . only down side is I have to use ethanol free gas or it leaves a residue in the jet and plugs it  ( all the new smaller sthl need it )  the next size up was
a lot cheaper but it weighed a few mor lbs
[th]MS 150 T C-E Specifications [/th]
DISPLACEMENT23.6 cc (1.44 cu. in.)
ENGINE POWER1.0 kW (1.34 bhp)
POWERHEAD WEIGHT2.6 kg (5.7 lbs)
FUEL CAPACITY200 cc (6.76 oz.)
CHAIN OIL CAPACITY150 cc (5.07 oz.)
OILOMATIC® CHAIN1/4" PM3
GUIDE BAR LENGTHS (Recommended ranges)30 cm (12")
STIHL ROLLOMATIC® E Mini
POWER SOURCEGas
STIHL recommends #3670 (71 PM3 64) OILOMATIC® saw chain and 12" 3005 008 3405 Emati
DelawhereJoe
Canadiana
Are they different than the cs330t
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
Canadiana
