turbo
Started by coxy, November 04, 2013, 06:55:08 PM
coxy
can any one here tell me if this is the right #turbo for a 518 cat 3304      4n6858   t04b91          id0180        not shur what is the right # but do any ring a bell  this is the 2nd turbo in 4 years  do they go bad that quick or are they not good turbos  any info will help thanks
wetdog
The "4N" number is the part number. Look on your engine tag and there will be an "AR" number. This is the engine arrangement number. Make sure you give this number along with the engine serial number to the CAT dealer to get the right one. They usually offer a reman insert without the inlet/exhaust housings, these are a little cheaper. You should be getting longer service than you are. Are the oil seals going out?
coxy
yes the oil seals and or bearings  are going bad its pushing oil out of muffler  does it every time  thanks
North River Energy
Are you in the habit of idling down for a bit before you shut off the machine?
wetdog
Idling down before shutdown is important so the turbo is not spinning excessively after oil pressure drops. Something else to check would be that the drain line under the turbo is not plugged/restricted. Dirty oil can also cause the bearings to fail.
