Cantilevered Millshed extension over my LT30
Started by Slingshot, June 06, 2010, 10:21:46 PM
Slingshot
Building an extension to cover my LT30. The Norwood I had worked OK inside the shed I
built for it, walking on the right hand side and loading logs on same side, but with the  Woodmizer
I needed more room on the left side so I set it up on the outside of the shed with not enough
overhang to cover it.
I built the shed to run water long ways from left to right and wanted the extension to drain to
the front so I cut some 2X's on an angle to give me a level ridge line for rafters and then put up
a steel beam supported by my main beams and extended it out for the center support:
And using long beams on the sides  attached to the main posts and supported by bracing: (I will add stronger
bracing):
Ready for the metal:
________________________________
Charles   sling_shot
paul case
when you get the metal on it will be in the dry. probably wont rain for a while but the shade will be handy. looks good ss.    pc
pc
