Yellow snow
Started by Treehack, January 14, 2017, 10:40:16 PM
Treehack
Trying to give new meaning to the term...
TK 1220, 100+ acres of timber, strong left arm.
newoodguy78
What were you milling up? The only thing I've seen with that color sawdust is locust? Either way you're doing a good job of turning things yellow  ;)
Percy
jmouton
just thinking the same thing percy,,,,,
lt-40 wide ,,bobcat,sterling tandem flatbed log truck,10 ton trailer, stihl 075,041,029,066,and a 2017 f-350,oh and an edger
Treehack
Quote from: newoodguy78 on January 14, 2017, 11:21:53 PM
Hedge
DPatton
That's a fairly new looking mill Treehack. How did it like cutting that hedge? I've been longing to run some thru my machine but just haven't taken the time yet.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
Treehack
Just got the mill a couple of weeks ago.  I get about 2-3 logs before having to change blades, except the one I destroyed... Thought I was raised up enough on return pass, but clipped the end of the log and pulled the blade off.  Broke off 4 teeth.
kelLOGg
Quote from: Percy on January 14, 2017, 11:22:30 PM
Dont eat it....  >:(
No plagiarism allowed on the forum. That's a quote from Frank Zappa. ;D ;D
Bob
DPatton
Oh I hate the loud bang when that happens....LOL. Sounds like the learning curve has started! That's a nice looking 1220 and congratulations on the new mill. I'm a TK owner as well.
YellowHammer
Only one tree I know of spits out that color of sawdust.  Congratulations on the logs and the mill.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Kbeitz
Smoke wood is also very yellow...   Cotinus coggygria
Love machine shop work
and Wood work shop work
And now a saw mill work
muggs
What is smokewood? That looks like Osage Orange to me.  Muggs
Kbeitz
Quote from: muggs on January 15, 2017, 09:29:19 AM
Cotinus coggygria
Brad_bb
Both Osage orange(aka Hedge, aka Bodark) and Mulberry will spit yellow sawdust.  What a way to start milling- with the hardest one out there.  Did you get any wavy cuts?  It can happen with Osage.
opticsguy
Alder will turn yellow after exposure to the elements and the sawdust, left untouched will do the same.
Happy to see someone else with a TK 1220, was starting to think I was along out here.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Treehack
Quote from: Brad_bb on January 15, 2017, 11:19:47 AM
All the cuts turned out good, but can certainly tell when the blade gets dull, especially with the hand crank.  I'm cutting 1/2 inch fence pickets so lots of cuts per log.
TKehl
Just be sure to leave room for a small stone or pebble for the top.  When the stone wears out, you will know it's time to replace the fence.   ;D
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
ChugiakTinkerer
I like those loading ramps you have.  I wonder if TimberKing sells those separately.  Would be better than using my leg as a log rest while repositioning the cant hook.
Woodland Mills HM130
bill m
Yellowwood tree is also yellow. I did some pruning on one some years ago at the Norman Rockwell Museum. I thought it was Beech at first until I cut a few limbs off.
Treehack
Quote from: ChugiakTinkerer on January 15, 2017, 03:10:18 PM
They do, but I bet freight to AK would be a killer.  I'm sure up there you have some logs big enough to need both legs.
Treehack
Been wet here for a week now, so not much sawing going on, so moved into construction mode a little.  Got a prototype fence panel for the garden built.
2 foot pickets on bottom for little critters, deer netting on top for big critters.  Only 39 more to go...
kelLOGg
Nice attractive panels!
We trapped more snakes in deer netting than we repelled deer, but then we put the netting close to the ground. Keeping it up higher would have avoided that. Nice design.
Bob
Treehack
Making progress.
got 10 panels built, hauled to property, and put up.  Found out that this many assembled panels were pretty awkward hauling on my little 4x8 utility trailer.  I decided that it would be best to finish cutting everything and then haul up the pieces to assemble on sight.
Have the remaining 60 uprights and 90 cross members cut, predrilled, and ready to assemble along with 305 pickets.  Only have 115 more pickets to cut and everything will be ready.
Treehack
Finished stack ready to load up.
Had my little 4x8 just about maxed, but made the hour and a half trip.
One batch assembled and ready to install
All done except the gate.
Had a small walnut log I wanted to bring back with me, but ran out of time and it was too dark.
Brad_bb
Wow that's a lot of osage boards to cut!  Good job!  That is the same trailer my off bearer has.  We fill it with slab firewood while milling and when full he takes it home to unload.
