This is Amazing......Making Cut Shells
Started by POSTON WIDEHEAD, April 02, 2015, 10:33:50 PM
POSTON WIDEHEAD
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
Don_Papenburg
That is cool ,but it makes reloading more of a chore.
POSTON WIDEHEAD
Quote from: Magicman on April 02, 2015, 10:39:18 PM
We called it "ringing the shell".
That was way back.....they started calling it "cut shells" in the 20's.
gspren
  Don't think they would cycle through a pump or semi too good.
goose63
A6 inch steal leader and split shot sinkers has a holding pattern that nasty
goose
thank you to all the vets
Don_Papenburg
Would a  large monofilament line work as well ? or do you need the weight of the steel ?
goose63
Don I don't think the monofilament line would be strong enough
goose
LeeB
Got any pictures of that Ken? Sounds fatal.
21incher
I wonder what damage that plastic shell does to the barrel? It is not the slippery plastic like wads are made from. I'll stick to 00 buck.  :)
james
the only problem with cut shells is, being bigger than the shotguns bore they can cause it to blow up in your face according a gunsmith neighbor :-X :-X
james
Chuck White
Quote from: james on April 04, 2015, 03:50:53 PM
james
Agreed, I would not fire one in a "full choke" barrel.
I would want a barrel that was open choked.
Now, I have fired 410's (that's my "around-the-house" squirrel getter) that have been reloaded unknown numbers of times and had them fire as cut-shells, but wouldn't do it on a regular or intentional basis.
Cut shells are illegal to possess during certain times while afield in Michigan as referenced in our hunting digest. Right along with buckshot and slugs.
http://www.michigan.gov/documents/dnr/hunting_and_trapping_digest_461177_7.pdf
pabst79
Quote from: Jeff on April 04, 2015, 05:22:17 PM
Slugs and buckshot are illegal here as well, can't carry slugs unless its deer season, go ahead and carry a 45-70 or .50 BMG while squirrel hunting, but slugs, NO way! seems like some laws are just silly at best ???.
Not sure which came first, but I have chickens and eggs.
goose63
Quote from: LeeB on April 04, 2015, 07:41:40 AM
no pictures but can get one place 4 split shot sinkers on one on each end two more in the middle squeeze them good and tight
when that thing spreds out its DanG fatal we used then in nam in 12 gage shot guns
goose
