Most useable Mill length?
Started by OlJarhead, October 24, 2012, 10:54:53 AM
OlJarhead
So while I'm asking all the questions here's another:
If you had a 14 foot mill (LT10) and were making a trailer for it and could lengthen the mill as part of that process would you lengthen it to make 14', 16', 18' or 20' lumber?
I've been thinking about this lately and at first I was gungho to extend the mill to 20' but then it occurred to me that the most bang for my buck might be no more then long enough to mill 12 or 14 footers.
Thoughts?
nas
No matter what, it will be to short ;D.  I find that I cut a ton of 16's so the ability to do that would be a minimum for me.
Nick
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
haywire woodlot
Go as long as is practical, when I first set up my old mobile dimension mill, I only used two track sections, thinking the 16' of cutting capacity was enough. After that every conversation with a neighbor went like this
Neighbour-"cool sawmill, how long a log can it cut?"
Me-"16'."
Neighbor-" That's too bad, I really need some 18' 2x8 rafters."
So, the longest you can make it, and still have it practical for you to move, is the best.
Dave
Chuck White
I tend to agree with the others, I would set it up so I could saw at least 16 feet!
bedway
Built mine to handle 16 ft but 14 ft. is the max ive cut. Most of the wood i cut is hardwood and not for structural use.
Nomad
     Go for at least 16'.  Realistically logs, cants any boards longer than that get hard to handle, store, etc.  And if your most common length is 12', for example, you've got plenty of wiggle room on the mill.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Riggs
Quote from: nas on October 24, 2012, 12:25:52 PM
No matter what, it will be to short ;D .
Nick
+1 I've already sawed a good bit of 20' beams.
Every man's life ends the same way. It is only the details of how he lived and how he died that distinguish one man from another.~Ernest Hemingway
Norwood ML 26
OlJarhead
Excellent feedback!
As I'm having the trailer built for the mill (Woodmizer LT10) I wanted to be sure it was a length I'd use but not so long that the expense of building it longer outweighed the possible returns.
In this case I have to go at least long enough to do 12 foot logs which means extending the mill a foot or two at the very least -- a 14' bunk on the LT10 only allows for about 11'4" of log because the mill head takes up almost 18" on either end of the bed.
So I'd be looking at a trailer at least 16 feet long which means a 20 foot trailer isn't much longer or much more expensive I think.
To do 16 foot cants I'd need a 19 foot trailer/Mill bed -- so 20 feet seems about right.  Plus I can pull it easily behind my F150.
I'm also looking at tandem 2000lb axles for stability, 8 stabilizers and some custom log loading ramps.  Also, I'm seriously considering setting it up to add a whinch at a later date and making it so the mill can be removed from the trailer.
I want to mill logs without having to remove the wheels so it will be a deck over arrangement but I'm thinking I can do it with shorter trailer tires and some fancy metal work so the bed of the mill sits a little lower then the top of the bed deck....I'll have to draw some pictures of that.
Anyway, thanks again -- I think 20' deck is what I'm going to do.
Then, if the business actually does more then just weekend sawing I'll look at a bigger mill :)
Dave Shepard
I vote for 16' minimum as well. I can saw 45' on the LT40 and it's still too short. :D
Red Clay Hound
If you plan to mill the logs on the trailer, 2000# tandem axles might not be stout enough.  By the time you include the weight of the trailer and the mill, you're not leaving a lot of room for the log.  I think I would use 3500# axles.  Just my 2 cent's worth. :)
2007 Wood-Mizer LT40 Super Hydraulic with 51 hp. Cat; 2007 Wood-Mizer EG200 Twin Blade Edger; Woodmaster 718 Molder/Planer; Stihl MS460 and MS362 Chainsaws; 2011 John Deere 5065 with JD 553 Loader
Brian_Rhoad
Build the trailer for 16'. Build it so you can add extensions to the mill to saw longer. If you build the trailer with the frame directly under the mill frame, make the trailer frame longer on each end so the extension sits on the trailer frame.
OlJarhead
Quote from: Red Clay Hound on October 24, 2012, 01:49:18 PM
I think that becomes a non-issue when you put the stanchions down.  They take up all the weight and stabilize the mill at the same time.  Am I wrong about this?
OlJarhead
Quote from: Brian_Rhoad on October 24, 2012, 02:17:01 PM
I'm wondering, though, if the LT10 is really going to cut long stuff all that well?  I haven't had a problem with it yet but it seems a bit light to be milling 16+ foot lengths for long right?
If I'm wrong, great!  But my hope is to get as much work with it as I can and then replace it with a bigger mill but to start I don't want to hamper my chances of success either.
So 16' millable lengths makes sense.
I like the idea of adding additional rails to make it longer but I think I'd have to do a lot of work for that - i.e. making the extensions stand the same height as the mill deck, not rack or dip etc and not require a lot of work to add (i.e. changing out the guide wires).
Red Clay Hound
Quote from: OlJarhead on October 24, 2012, 02:27:56 PM
You are correct.  If you will be using outriggers on your trailer then the weight of the log becomes a non-issue.  Why didn't I think of that? say_what
hackberry jake
I would vote for 16, minimum as well. A lot of 16" trailers out there need new decking. I can cut 22', and have done so twice (for the 6x6s I have the mill sitting on), but never want to again. I don't have the equipment for 22' long logs. That's a lot of weight and they have to be gun barrel straight or you waste more wood than you make into lumber.
QuoteI'm wondering, though, if the LT10 is really going to cut long stuff all that well?  I haven't had a problem with it yet but it seems a bit light to be milling 16+ foot lengths for long right?
Length of log doesn't really affect the saw head, just takes longer to get through the log. No more stress on the saw head etc. The Woodmizer site actually shows the ability to add unlimited bed extensions as one of the mills selling points. Not sure how you are supposed to handle a 40ft log, but if you lined up enough track extensions the mill could work it's way through it
The only issues are supporting and turning the longer log. If the mill rails are supported by the trailer frame, that's supported by jack stands, then holding  the log isn't an issue.
Turning it? Well you are on your own there  :D But it's the same as any other manual mill in that respect.
I'd go long, because then you have to option of cutting things like longer beams and rafters etc. The "oddball" jobs that you will be looking for, and the little mill will handle quite well. You want to be able to cut the stuff people can't buy off the shelf. 8 ft 2x4? Meh, probably buy those cheaper than you can mill them?  A 16ft 8 x 10 beam? 4 cuts and it's done, load the next one... Charge $50 an hour, no worries. You won't be much slower than any other manual mill.
Edit - log handling become an issue, but hopefully anyone wanting heavy stuff like that has a tractor or similar on hand to move logs and beams around, or else how are they going to move the stuff after you do cut it?
QuoteI haven't had a problem with it yet but it seems a bit light to be milling 16+ foot lengths for long right?
If you are just adding track extensions, the mill really doesn't know it is cutting 8' or 20' logs.  Or am I missing something?
Or is the operator going to get tired being in the cut that long?   ;D
JustinW_NZ
As Ian said, watch for things getting more problematic as logs get longer the weight does seem to pile on them!
Cheers
Justin
Gear I run;
Woodmizer LT40 Super, Treefarmer C4D, 10ton wheel loader.
Nomad
     Don't forget that longer logs usually mean fatter logs.  The LT10 can only take so much diameter.
Lucas DSM23-19
POSTON WIDEHEAD
Quote from: nomad on October 24, 2012, 09:03:22 PM
24 inch.
Bill Gaiche
I would go for 16.5' at least. You may get some orders for trailers that need new floors. That extra 6" lets you trim the lumber to an even 16'. I have 2"x6"x3/16" tubbing under the 3" angle iron frame rails and it is very strong. Build your own 2" schedule 80 tube axle You can buy axle stubs with hubs pretty reasonable,weld them in the end of the tube. Make you some spring pads and spring hangers also. Build the axle only as wide as the width of the saw frame plus a little clearance. The wheels don't need to be removed because they don't stick out far enough to get in the way. Purchase you some springs that will handle a total of about 2000lbs to go under the rectangle tubbing. Your mill can be welded to the tubbing or bolted down so you can remove it if needed.Add you a tongue and you will have you a portable mill that will work great for you.My mill will only cut 12.5' lumber and that all I need 99% of the time. bg
I have a manual mill that will cut 20 feet. I never have cut nothing longer than 16. But this longer mill gives me 4 feet of extra room to play with instead of 6 inches on each end when cutting 16 foot logs.It also allows me to get the head out of the way to remove boards too.Ever had to move even a 10 foot log,16 inches through, 6 inches, length wise on a mill? I think you will be cutting alot of 16 foot but not many 20's. That extra 4 feet is great when cutting 16's. I brought the longer mill just in case. I had no idea how much easier it would be to have the extra room. I would make it 20 feet if I was doing it.
OlJarhead
Bill I'd love to learn more about your mill!
One 2000lbs capacity axle and tires would be a lot cheaper then what I was looking at (a pair of them with brakes on both since the state requires it on 3000lb gross and above) and the simple design would work fine I think -- only I need a walkway beside the LT10.
I'd like to see more detail on your clamps too!
The really long logs on the LT10 will kill you.  You might not be able to turn them without damaging the mill, yourself, your tractor or all of the above.  It is not designed to cut long length construction lumber in my opinion.  If your strategy is to cut long construction lumber, I believe that you have the wrong mill.  You can make it do it, but you are pushing up a rope in my opinion.  Also, if the mill is trailer height, it is almost impossible to turn the big long logs by yourself with a cant hook.  You need help.  It is many times easier to turn bigger logs if the mill is low to the ground, because, otherwise, you can't get leverage to turn the logs.
This log took an hour to load, was very dicey, and ended up too big to fit between the blade guides.  Much more chainsaw work ensued.  A lot of suspense and drama for sure.  I was scared a few times, said a few DanGs, but finally got it done.  The 22" wide by 9' long 6/4 oak was nice, but almost impossible to handle and stack.  And, this is a LT15, which is much beefier than the LT10.
If you are going to be cutting big, honking, long logs, then HYDRAULICS.
OlJarhead
I envision mostly cutting pine and fir around where I'll be -- not much hardwoods growing.
Also imagine I'll be cutting mostly smaller stuff (15" to 20" max most of the time with a lot of stuff in the 12-15" range probably.  That's just from what I've been falling and cutting on my own property but I think it's pretty representative.
My trailer plan was to have at least a walkway along the mill on one side, if not both sides -- so I'd have a place to work to turn the logs from.
I think that is a good plan.  A 16" pine versus a 26" oak are very different animals.
tcsmpsi
I'll go the 20" max on a manual mill, unless it is a very special log or circumstance.  Even then, save it until you have minimum to no time constraints to 'bother' you.  At 20", I sure wouldn't want anything over 10' to handle on the mill.  Well, maybe ERC.   ;D
WDH, I do believe I see some improvements made.   Looks good.
On the length, I can cut 20'.  But, the only thing I would normally cut that length are framing materials.  Maybe some posts/beams.  Mine will, but handling a log that size of anything worth sawing that length can be a real challenge by hand.  Also, a mention on length as far as the mill deck goes, I would suggest utilizing the length of the rails (moving shorter logs) as much as possible.  I have noticed a bit of wear on the rails over the years.
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
Bill Gaiche
Okrafarmer
I would do about 17' to give you that extra foot of leeway. Really 6", since you do want to leave a little trim on the logs. Get yourself going with the LT-10, then once you're established, get a used hydraulic mill.
Now selling Logrite tools!
Sixacresand
I got an bed extention with my Lt10.   I try to avoid the long, fat, heavy logs.  But it is good to know I have the capability.  Presently I have 6' lumber stacked, stickered and drying on one end of the mill.
OlJarhead
OlJarhead
Doesn't sound like there is much cost difference between getting a trailer long enough to do 14' logs (which means 17' trailer) vs. 16' logs (19 foot trailer) so I've suggested to my guy to plan on making a 20' trailer and I'll use the extra space for a longer rail (meaning I could do over 17' logs) for storing stuff etc.
dgdrls
when your done, I hope you load a pic or two.
I'll add this, inquire about a torsion bar axle,
it will save you the height of the springs over the axle,
and they tend to ride smoother.
DGDrls
Too Big To Fail
My mill can cut 20'6" logs, and my first job was 4 days cutting 2x12x........20'6"  :)  Fortunately the guy had a forklift for handling.  To get that length I have to tuck the log into the carriage head.  I find myself wishing I could do 24' but that would be too much trailer I think.
OlJarhead
Have at least two different people coming to look at our ATV trailer (8x12 flatbed) and if I can get it sold off then it will over about 75% of the cost of building my mill trailer :)
With luck I'll turn this conversation into a build thread!
OlJarhead
SOLD!
Now I just have to get started with the trailer build.  I'll get some pictures once it gets started and start a specific thread on it.
Thanks for all the feedback!  I'm going with a 19 foot minimum so I can cut 16' logs so the trailer will be 20' unless something comes up.
Erik
Bill Gaiche
  I have a few more photos of my clamps and back stops. I only have 2 each. I use a 2000lb winch to turn my logs and it has turned every one so far just fine. I have a manual boat winch to operate my toe board. Hope this helps and you can look in my gallery for a few more photos. I tried the torsion type springs, china made, and one settled down lower and made the mill set at an angle. Then built the spring over pipe axle and wish this is what I did the first time. You may have better luck than me on the torsion spring. bg
OlJarhead
Great pics!  Thanks!
I'll have to discuss with my trailer guy (I'm not the metal work type but he's willing to have me help him to reduce costs -- his offer -- and yes, great guy!) about how we can set up to do these kinds of mods later.
First I just want the mill on the trailer pretty much as is except maybe a toe board attachment to lift the end of the log.  Then if I start getting business then I can do some other stuff to help make it easier to operate alone (I like the 2000lbs winch idea with the log turner).
Okrafarmer
You can also use a hydraulic jack for a manual toe board lifter. Install it (permanently or semi-permanently) in your frame. Then it's easy enough to make two of them (now or later), so you can lift either end of a log, meaning you don't always have to put the big end one direction.
Solomon
I dont know we have a lot of pine here in Va and I see a lot of them 80 ft tall  straight up 60 ft before any limbs  and their 12 inches in diameter.   Looks like yellow pine to me but I could be wrong,
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
Okrafarmer
Some pines definitely do that. The ones you are looking at probably are some type of yellow pine, though white pines can be slender too. Some trees have a very low aspect ratio, and a very low taper ratio. Others-- hmm. Not so much.
