LT-28 Storage
Started by JMoore, September 18, 2012, 04:53:28 PM
JMoore
 Caveman and I have a LT-28 and it goes through periods of little to no useage. My question is should we store the head in the travel position during these times in between use ?? I never gave it much consideration untill I read the post about trailering long distance and worrying about the single mast thing.
  Thanks, John
submarinesailor
If it is not going to be moved while it is not being used, I would store it with the head all the way up.  We have found out it really helps in keeping the @#$%^&*()@#$%^&*() mice out of the motor.  Thar's what we do with our LT15 anyways.
Bruce
Chuck White
I store my mill with the head lowered onto the rest pin through the winter.
I just lower it solidly onto the pin and the operator side is lowered until it sits on the bolts at the bottom of the mast!
Chuck White
Quote from: submarinesailor on September 18, 2012, 05:42:26 PM
Bruce
Bruce; John is talking about an LT28, whole different machine than the LT15.
JMoore
Thanks Bruce and Chuck for the replies that is what I'll do from now on it certainly wont hurt and probably help.Chuck is correct it is quite a bit different than the LT-15.   Thanks again , John
