Council Tool
Baltic Abrasives Technologies
Author Topic: Sawing a large walnut log  (Read 3196 times)
Offline Wes06
« on: April 16, 2018, 09:01:03 PM »
I'm looking for someone in central illinois to cut a walnut log for me.  Its 48"◊28" on the bottom and 63"◊28" on the top its 7ft long . Im wanting them cut in 2" thick slabs.  Also how much it would cost to have done?
Offline Brad_bb
    • My timberframe blog
Re: Sawing a large walnut log
« Reply #1 on: April 16, 2018, 10:38:23 PM »
It's not clear the size to me.  Typically you'd give the diameter at the bottom and the diameter at the top.  If it's a crotch at the top, you'd indicate the spread at the crotch and the diameter of the two secondary trunks(or at least the largest one).
Are you wanting this slabbed for table top/counter tops?  If so, and it's greater than 36 inch diameter, you'll either need someone with 1)a big industrial band mill, or 2)someone with a Petersen or Lucas slabbing mill, or 3)someone with an alaskan chainsaw mill with wide enough capacity.
Which one depends on 1)who has what around you, and 2)whether or not you can bring the log to them or they have to come to you. I'm sure their charge will be less if you bring it to them, but you will have to bear the cost for the hauling each way.  So it may pay to go with option 2 or 3 and have them come to you.  Do you have a forklift to remove the slabs as they are cut?  You'll also need to move them to a place on your property where they can air dry.  Do you know how to sticker and cover them?  You'll need to have stickers on hand to space the slabs apart for air drying.  Slabbing Could likely start at $100/hr.  Could easily take 3 hrs, maybe 4, plus travel.  But right now big nice walnut slabs are worth it.  Selling just one of the slabs could pay for the milling.
Post a pic of your log.  It's easy these days by having the pic on your computer and clicking the blue button while typing a post to add a photo.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #2 on: April 17, 2018, 09:34:08 AM »
Too big for my current equipment.  (48" max.)
If you are willing to trim 3-4 inches of width off the wide end, it would fit on more slabbers.  Keeping a full 63" width will need a Lucas dedicated slabber (or similar) or an Alaskan chainsaw mill.
Lucas 6-13+slabber, Mr. Sawmill bandmill, orange chainsaws, JD SSL, Case Backhoe, farm tractors, trailers, and 150ish acres of trees.  Fledgling woodshop with CNC router, laser engraver, Woodmaster 712, and a Berlin 108 moulder (project).  Oh, and a lovely (patient) wife and four offbearers.
Offline Wes06
« Reply #3 on: April 17, 2018, 06:44:46 PM »
Yes I have a forklift to move it around.   I also would like to keep as wide as possible for a table or countertop
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #4 on: April 17, 2018, 07:19:26 PM »
Can you bring to to south Carolina?  ;D
Offline Wes06
« Reply #5 on: April 17, 2018, 07:45:51 PM »
  If any way possible I'd like to stay with 200 miles from Decatur il .   South Carolina is alittle far for me.
Offline Treehack
  • So many logs...So little time
« Reply #6 on: April 17, 2018, 08:58:17 PM »
I'm in Bloomington, but I can only get 29" between guides, so would only be able to slab the 28" dimension.
TK 1220, 100+ acres of timber, strong left arm.
Offline Wes06
« Reply #7 on: April 17, 2018, 09:32:52 PM »
I like how close u are but I wish u could do 63".   If it comes down to it ill go with the narrow part but for now I'm still trying for the 63" thanks thought
Offline Brad_bb
« Reply #8 on: April 17, 2018, 10:01:02 PM »
Wes06, there's a guy about 25 minutes west of me who has a Lucas slabbing mill.  I have not used him.  I'll PM you.   By the way, you can put your location (town and state) in your profile and it will show up in each of your posts.  That way people can better advise you when they know where abouts you are.  Do not cut your log narrower.  If you have the ability to load and haul it, what's a few hours driving?!
Offline ToddsPoint
  • Stockmaker and Carver
« Reply #9 on: April 18, 2018, 05:32:36 AM »
I'm down by Findlay and can do 32" with my chainsaw mill.  I think that log is probably too heavy for my Logosol M7 though.  63"?  Wow!  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Offline nativewolf
  • Forester
« Reply #10 on: April 18, 2018, 08:57:07 AM »
Lots of guys have Lucas mills.  Keep looking and don't mess up that crotch.  The crotch looks great, very little sapwood; I am starting to have quite the stash of walnut crotch logs built up.
Liking Walnut
Offline Savannahdan
  • Retired.
« Reply #11 on: April 18, 2018, 09:20:43 AM »
Nice log.  It's going to take someone with at least a 6' CSM or wide BS to get you the 63" you're wanting.  I have a 56" CSM but it only nets out around 52-53".  Good luck.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #12 on: April 18, 2018, 09:56:50 AM »
Check out this guy, I'm pretty sure his home built band mill would slice your log.
https://www.mattcremona.com/
1992 LT40HD
Offline nativewolf
  • Forester
« Reply #13 on: April 18, 2018, 12:59:30 PM »
Oh good idea.  Matt is very nice guy, he'll reply pretty quick too.
Liking Walnut
Offline Brad_bb
« Reply #14 on: April 18, 2018, 08:08:10 PM »
Remember that dining tables are 42 in wide max typically.
Offline Wes06
« Reply #15 on: April 18, 2018, 08:34:15 PM »
Thanks everyone for the info.  I have some thinking to do on what I wanna do with it
Offline Brad_bb
« Reply #16 on: April 18, 2018, 09:53:35 PM »
Conference tables can be wider.
Offline Wes06
« Reply #17 on: April 21, 2018, 01:03:49 PM »
If I decided to sell the log as is would it be worth anything?    Or if I was able to get it slabbed into 2" thick how much would the slabs be worth?
Offline nativewolf
  • Forester
« Reply #18 on: April 21, 2018, 01:54:39 PM »
Well the issue is the 7'.  You may get 500-1000 for it depending upon the buyers.  I'd think the slabs would be worth more though, that's a local market.  Check your craigslist.
Liking Walnut
Offline TKehl
    • Kehlhof Ranch
« Reply #19 on: April 23, 2018, 10:54:29 PM »
1st step, slather some anchor seal on the ends to reduce checking.  Then relax.  Walnut will last a long time before significant degrade other than the sap wood usually gets darker.
It can be milled, just not a lot of equipment out there that can go that wide as it's pretty specialized.
Started by Wes06 on Ask The Forester
Last post April 16, 2018, 08:39:03 PM
by Wes06
Need sawing advice on large walnut logs
Started by rbp3 on Sawmills and Milling
Last post July 13, 2010, 11:04:29 PM
by WDH
For Those Who Like Large Walnut Logs
Started by Glenn1 on Sawmills and Milling
Last post December 20, 2015, 12:06:27 AM
by YellowHammer
was sawing some walnut and oak today - is walnut made of concrete???
Started by Andy B. on Sawmills and Milling
Last post September 15, 2013, 09:58:31 PM
by Gasawyer
