Lube running when it shouldn't
Started by Jjoness4, August 11, 2018, 10:04:33 AM
Jjoness4
Without taking the cover off and looking at the design, I am taking the lazy man's way out and asking you guys.
Lube is running even when carriage drive drum switch is not activated.  Is the solenoid for the lube flow just a pinch valve type design (on/off). Is the solenoid not pinching the Tygon hose sufficiently? Or is the solenoid defective?   Advice welcome.
2017 LT40HDD35 , Kubota 4701, Ford 3000, Stihl Farmboss
Percy
I would start at the solenoid with a test light or a muti meter..If yours is the gravity system and its stuck on, Id almost bet a canadian dollar ;D that its the solonoid. Chances are a piece of sawdust found its way in there and has it stuck open...
terrifictimbersllc
If you have the Lube Mizer system then the problem will be check valves which are either defective or need cleaning.
sparks
Your mill does not have a Lube-Mizer. It has a water shut-off solenoid mounted under the water bottle. It is either stuck open or has debris in it. Either way it is covered under warranty.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Sixacresand
How did you fix it?  Replace it, clean it out?
