Author Topic: Baker Edger  (Read 2240 times)
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
Baker Edger
« on: February 08, 2018, 08:48:12 AM »
After much research, pestering, considering, delaying and rethinking, we ordered a new Baker edger last week.  I investigated  pretty much every edger I could, new and used, and tried to find one that would fit in with our production scheme.  I wanted horsepower, very straight, wide and thick cuts, variable feed, safety, reliability, and company support.  I was not sold on either belts or rollers, and looked at both.  I needed at least 3" of depth of cut, and the ability to work with green or dry wood, so I wanted to be able to change blade teeth count, and have a supplier that could provide me different blades.  I looked at old iron, and even the larger, production grade edgers.
The edger I ordered is a stationary belted Baker, with quite a few of the optional upgrades.  I am having them install a 20 hp 3 phase electric motor with the 12 inch split blades which will give it the ability to edge 3 inches thick.  I also ordered the extended infeed belt and roll case to stabilize longer boards and also provide straighter cuts on standard 8 footers.  It will have a remote mounted hydraulic blade shift, infinite hydraulic variable speed feed, and twin lasers.  It also has a dust collection pan and chute.
I intend to use it for both edging straight off the mill, but also as a post drying edger.  With all the quarter sawing we do, all the slabs we have been selling and other stuff we have been going, I need tool that can grind wood in a hurry.  Our SLR works great, but has only one blade, and I can't run green wood on it, or its cast iron bed will rust.  Baker has the ability to get me different tooth count blades if the standard ones give me issues in the dry, thick wood.
I've read how the blades are difficult to change, but this machine was the only one that could meet almost all of my requirements, so I will have to deal with it best as I can.
The bad news is a three month wait to get it built.  Oh, well, I wanted 8 months for my tractor, so it could be worse.
HobbyHardwoodAlabama.com
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Baker Edger
« Reply #1 on: February 08, 2018, 09:14:43 AM »
Good deal!  The ability to edge a 3" slab would be a must for me as well. Heck, when it comes to mantles, 4" would be nice.
Congratulations for a growing business and all the hard work that's gone into it!
1992 LT40HD
Offline xlogger
Re: Baker Edger
« Reply #2 on: February 08, 2018, 06:04:42 PM »
congrats on the edger. I believe you made a good choice.
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Baker Edger
« Reply #3 on: February 08, 2018, 06:20:46 PM »
Lets hope it will do all you want. :)
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline PAmizerman
  • Just Another Day In Paradise!!
Re: Baker Edger
« Reply #4 on: February 08, 2018, 06:28:59 PM »
Sounds to me that with all those upgrades there are likely to be some bugs that need worked out.
So just have it shipped to my address and I'll contact you after I get them all worked out!!!
Seriously though congrats. I've been eyeing up an edger as well. That's on the back burner for now though. Next equipment I'm getting is going to be a sharpener and setter.
Traverse 6035 telehandler and a lot of back breaking work!!
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Baker Edger
« Reply #5 on: February 08, 2018, 07:25:42 PM »
You can't do nothing with a man with money!  8)
Where's the Spoon?
Offline PA_Walnut
Re: Baker Edger
« Reply #6 on: February 08, 2018, 09:04:00 PM »
Congrats! I have a Baker with a diesel. It's awesome.
You'll wonder how you ever managed w/o it when your quartersawing!
Thinking about going electric mill and edger later this year. Is your mill electric too?
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline JB Griffin
Re: Baker Edger
« Reply #7 on: February 08, 2018, 09:07:47 PM »
Congrats on the great new edger you'll love it.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2 million bdft sawn with a Baker Dominator and counting.
Offline moodnacreek
  • Sawin by the notches
Re: Baker Edger
« Reply #8 on: February 08, 2018, 09:38:28 PM »
The variable feed option should make the difference. I have 4 speeds on my edger and in creeper I can follow the guide lite by hand on a thick difficult piece. However I can not do thick dry both sides, too much chatter, but my saws only have 14 teeth. The most important thing on an edger is the diameter of the mandrel, the thicker the better and a lot more $. With slow feed and fine tooth saws I think it will do the dry for you.
Offline JB Griffin
Re: Baker Edger
« Reply #9 on: February 08, 2018, 09:45:23 PM »
Baker runs a 2" mandrel I believe.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
Re: Baker Edger
« Reply #10 on: February 08, 2018, 10:17:16 PM »
 8) 8) 8)
Boy, back in my day..
Offline Southside logger
Re: Baker Edger
« Reply #11 on: February 08, 2018, 10:18:35 PM »
Funny thing was yesterday I saw a Baker Edger go by on the back of a trailer - I about drove off the road careening back when I realized what it was.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
Offline PAmizerman
Re: Baker Edger
« Reply #12 on: February 08, 2018, 10:41:37 PM »
If you end up going electric and sell the edger let me know. I'm not to far from you
Re: Baker Edger
« Reply #13 on: February 08, 2018, 10:44:04 PM »
Me too ::)
I'm running 20 tooth 12 inch blades in my SLR and they eat through the 3 inch wood plenty fast.  I'm hoping the Baker will do the same.  I talked to several companies about my needs and it was interesting getting the different responses.  Most were "take it or leave it" and one was even "Sorry, our machine can't do that." Baker was the only one I talked to who said "You tell us what you need, we will build it." BTW, the Woodmizer commercial series are fine machines, and were runner up, they just could not get me the depth of cut I needed.
PA, my mill is a Diesel, and has never given me a hint of trouble, but if I had to do it over again, I would deifinly go electric.  I can't get 3 phase, but since I installed the phase converter and have been using the bigger electric motors with my other tools, I've have gotten used to the benefits of electric.
Re: Baker Edger
« Reply #14 on: February 08, 2018, 11:05:32 PM »
YH - funny what you just said about Baker. I have been talking with Luke about a mill this week and he said the same thing, tell us what you need. He even asked a bunch of questions about my operation so they can evaluate what I am trying to do and see what might fit best.
Offline tmbrcruiser
Re: Baker Edger
« Reply #15 on: February 09, 2018, 05:42:52 AM »
Congratulations on the upgrade, I don't think you will be disappointed. I have a Baker edger with 20 hp electric and love it. All of your upgrades sound like the cats meow (sorry for the oldie). One word of caution the kick back fingers on my edger were spaced 3/4" and the tips were thin enough to curl. I took out the spacers and put finger side by side , problem solved.
Once you get sap in your veins, you will always have sawdust in your pockets.
Re: Baker Edger
« Reply #16 on: February 09, 2018, 07:34:45 AM »
Good suggestion on the fingers.  Do you know how many new ones you had to put on?
Online Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Baker Edger
« Reply #17 on: February 09, 2018, 09:03:34 AM »
WM does offer an edger that will cut 4" thick, but you'd need two 4x4Americans with LT70 Supers to keep it fed.  ;D
Offline B@kerLuke
Re: Baker Edger
« Reply #18 on: February 09, 2018, 09:33:52 AM »
YellowHammer, thanks for the order!  You won't be disappointed, and we look forward to hearing your stories of success using the edger.  It's great to hear that our products perform well and get folks excited when they see them, let's just try not to run off the road while being mesmerized! :D  Stay safe out there, and keep sawing!
Offline 4x4American
    • Website Link
Re: Baker Edger
« Reply #19 on: February 10, 2018, 01:47:04 AM »
 :D :D :D
Hey I need two 4x4americans over here!!!
Baker edger
Started by xlogger on Sawmills and Milling
Last post October 06, 2016, 10:50:17 PM
by Brucer
Baker circle board edger
Started by paul case on For Sale
Last post July 01, 2017, 12:07:55 PM
by paul case
Baker 2" Twin Blade Portable Edger - $6,500
Started by Warren on For Sale
Last post March 21, 2012, 04:55:10 PM
by Warren
Mixed marriage at Bibbymans Baker-Mizer or Wood-Baker?
Started by Bibbyman on Sawmills and Milling
Last post February 10, 2008, 07:53:01 AM
by beav39
