BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Poison oak & poison ivy  (Read 1207 times)
Offline jtimbermill
« on: February 08, 2018, 09:10:09 AM »
To all you sawyers out there that cut their own trees to mill, how do you deal with the poison oak and ivy.  My property is covered with and it seems like I have a continuous case.  Are there any old school remedies. Are there any suggestions on how to clear the property of this menace.  I have 3 boys that run all over the place but it seems that I am the only one that has issues. I wear gloves and long sleeve's but during the summer it is just to hot to dress like a bee keeper. Any advice would be great.
Offline StimW
Re: Poison oak & poison ivy
« Reply #1 on: February 08, 2018, 09:15:28 AM »
Rule #1 , NEVER burn it!
When you burn it the oil becomes vapor and can be inhaled getting in your lungs/airway which can be fatal!
New HF Band Mill
Branson 35 hp 4 WD Diesel Tractor W/Attachments- Backhoe, FEL W/ Bucket or Forks, 4' Tiller
4000# Clark Forklift W/24" Tires
Promark 6" Brush chipper W/18 hp Kohler
Offline goose63
« Reply #2 on: February 08, 2018, 09:25:54 AM »
The last time I had poison ivy on my arm I used a stiff scrub brush on the blisters then bleach it's gona burn like the dickens but the poison ivy was gone the next day
goose
thank you to all the vets
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #3 on: February 08, 2018, 09:26:23 AM »
DONT TOUCH NUTTIN HAIRY!
Forestry Forum Founder and Chief Bottle Washer.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #4 on: February 08, 2018, 09:27:11 AM »
Check out health food stores or natural food/remedy stores, my wife used to go there and buy a bottle of pills with the name "Poison Oak" on the label. Don't know if you can still get it or not, haven't seen any of it in over 20 years. Have no need for it here as poison oak doesn't live here.
1992 LT40HD
Offline goose63
« Reply #5 on: February 08, 2018, 09:28:43 AM »
And don't use for toilet paper just ask my brother how he knows
goose
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #6 on: February 08, 2018, 09:39:12 AM »
Aside from spending loads of money on chemicals just get some goats they will eat the stuff and depending on what kinda goats you get, the bigger the goat the higher it can reach. You can also harness train a goat and will pull around 200lbs so you boys could start there own goat racing league. There also good for meat, cheese milk and as pets. I've found an over mix of Roundup, 2,4D and bush-b-gone very effective on killing the ivy and keeping it dead.
Offline Darrel
« Reply #7 on: February 08, 2018, 09:44:17 AM »
Don't know if it's true, but I've heard that if the goats eat the poison oak/poison ivy and you drink their milk you will become immune.
1992 LT40HD
Offline Sixacresand
  • John and Nancy
« Reply #8 on: February 08, 2018, 09:53:07 AM »
I am highly allergic to it.  "Leaves of three, let it be".  I found that if I take Benadryl or OTC antihistamine, it doesn't bother me so bad.  It will make you drowsy, so you got to be extra careful while using equipment and tools.  Sometimes, it so bad, I just go to the ER or Dr. and get a shot.  As a teen, we used to pull on vines going up into a tree to run squirrels out of their nest.  Big mistake!  And be careful what you put on the campfire.  the PI smoke can be very potent.  Dogs running in the woods are like PI paint brushes when you pet them.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #9 on: February 08, 2018, 09:56:59 AM »
I am highly allergic to it.  "When I see leaves of three, I let it be".
Lots of plants have 3 leaves but poison ivy has a chunk
missing on one of the leaves. Or an indent.
Love machine shop work
and Wood work shop work
And now a saw mill work
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #10 on: February 08, 2018, 09:58:11 AM »
I must have drank goat milk one time from a goat that ate some money.
Offline Darrel
« Reply #11 on: February 08, 2018, 10:07:18 AM »
:D :D :D :D :D
Me too!!!
1992 LT40HD
Offline Crossroads
  • Let's make some sawdust!
« Reply #12 on: February 08, 2018, 10:34:22 AM »
Did you know it takes 3 goats months to clear a blackberry patch, but only 15 minuets to strip all of your apple trees 😤
2017 LT40 wide, Kubota l185dt, 2001 Dodge 3500 5.9 Cummings,
Offline clearcut
« Reply #13 on: February 08, 2018, 11:52:09 AM »
Oh, the summer of 1988. I was the field crew chief for a research project measuring oaks in California oak-grass woodlands. Poison oak surrounded nearly every tree. All of the crew members got poison oak at some point in the study.
What worked for us to reduce the incidence:
     Protection - long sleeves, gloves,
                       removed before entering the vehicles
                       and washed separately from all other clothing.
     Washing contacted skin with COLD water only - no soap - rinse then scrub with a paper towel
     Rinsing washed skin with isopropyl alcohol
     Some folks used Tecnu with mostly good results.
Though I have not used it, some folks recommend Bentoquatam (a form of bentonite clay) containing oak-ivy blockers. IvyBlock is one brand.
Another treatment that works for poison ivy is to rub suspected contacted areas with crushed jewelweed (Impatiens capensis) leaves found at the boundaries of wetlands.
We never found a non-prescription remedy better than calamine lotion - possibly improved by sipping goat's milk.
Offline Deere80
« Reply #14 on: February 08, 2018, 12:30:30 PM »
Spray it with Milestone, mix a 1/2 once per 25 gallons of water.  Buy it from your county weed board and during the spring they with cost share it depending on how much land you have.  It will kill it quick, like four hours the leaves will be drooping already.
Wood-Mizer LT35HD
Offline Southside logger
  • Sawing so I can afford to farm.
« Reply #15 on: February 08, 2018, 06:56:48 PM »
Wash with Tecnu, I keep a bottle in the truck. Excellent stuff.
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline submarinesailor
  • LT15 and a wife of 45 yrs
« Reply #16 on: February 08, 2018, 08:13:01 PM »
I LOVE TECNU!!!!!!!!!!!  I keep a quart bottle of it in the bathroom so I have it when I need it.
Offline firefighter ontheside
  • I like trees.
« Reply #17 on: February 08, 2018, 10:14:11 PM »
Wearing long pants and sleeves only helps if you wash the clothes immediately and wash yourself after handling the clothes.  Many people think poison ivy spreads.  I have a friend who gets it all the time.  She said it was spreading and I told her, no youre continually being exposed to it.  It may have been on the dogs, dogs got it on furniture, etc.  Take a good hot soapy shower to remove the oil.  My grandma taught me to use white vinegar.  After being exposed to poison ivy, I will soak a paper towel in vinegar and wipe down arms and legs.  I have not gotten poison ivy in many years.
Woodmizer LT15
Kubota L245DT
Stihl 025 and MS291
2017 F350 Diesel 4WD
Online POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #18 on: February 08, 2018, 10:27:57 PM »
 smiley_guitarist smiley_trap_drummer
Where's the Spoon?
« Reply #19 on: February 08, 2018, 10:29:43 PM »
I've ate it but it makes my butt itch.  :D :D :D
Goat
Where's the Spoon?
Offline starmac
« Reply #20 on: February 08, 2018, 11:28:49 PM »
I do not know how common it is, but I am one of the lucky ones, I could get naked and roll around in it with no ill affects. My dad was the same way, and his sisters were highly allergic to it, as was mine.
Offline ToddsPoint
  • Stockmaker and Carver
« Reply #21 on: February 09, 2018, 05:37:43 AM »
Poison oak and poison ivy are two different species.  Oak and ivy in the west are different species than in the east so you have four different species total that are poison.  The western stuff is a lot stronger than the eastern version.  Tech-Nu works great for eastern but I've heard it's not as good for western.
There is also a product called Ivy Block.  You put it on before you go in the woods.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Offline thecfarm
« Reply #22 on: February 09, 2018, 07:47:35 AM »
Some of you guys talk about that stuff vining up the trees.  :o
I just have the poison ivy. I have some on the edge of he woods. Thank God I own the woods. I have really been trying to kill it back. We,my Father and I would only spray it,total vegation killer,every few years. I Have been right at it. If it's short and green,it gets sprayed. Short as one foot tall. I might,I said might,be gaining on it. Hard stuff to kill in the woods.
I bought back some of The Farm. There was a so called stone wall that was covered in that stuff. There was a few bushes,but it was on the edge of the road and a field trying to go back to a forest. I kept that wall barren for 3 years. If it was green,it got sprayed. It did not matter if I knew it was grass,it got sprayed. I got rid of the poison ivy and it's been at least 5 years of mowing and has not came back.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #23 on: February 09, 2018, 07:53:14 AM »
Starmac,
   I'm like you but I get it on me or my clothes and never know I have been in it then my wife gets it. I think it would be easier to live with if I just got it, :(
« Reply #24 on: February 09, 2018, 08:09:02 AM »
cfarm -
Around here you will find vines large enough that you could put the main trunk on your saw and cut it, the vines will go up 30' and branch out 20' to the sides hanging clusters of berries that look like small grapes - and I am not exaggerating.
Hot wife
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #25 on: February 09, 2018, 08:23:16 AM »
I sawed some ash logs which were covered with poison ivy.  Customer got it from head to toe, his wife was telling me about it, too much information.  :-X :-X
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline florida
« Reply #26 on: February 09, 2018, 09:22:41 AM »
Poison oak and ivy are among the easiest vines to kill. I usually use Brush Killer mixed with water. In a week the leaves are gone at which point I cut the vines with a machete then leave them alone. In a year they rot and fall out of the trees.
The rash is caused by the sap which is called urushiol.  Urushiol is actually used in Japan as a wood finish.  It does not come off with water or bleach anymore than pine sap does. It does come off with turpentine, mineral spirits or if you're in a hard spot use gasoline. Tecnu is nothing more than creamy mineral spirits.
I am as allergic as anyone and encounter poison ivy frequently. I don't go out of my way to let it touch me but wipe my arms with mineral spirits at lunch and the end of the day.
General contractor and carpenter for 50 years.
Offline Sixacresand
  • John and Nancy
« Reply #27 on: February 09, 2018, 09:54:51 AM »
Goat
You probably said that as a joke.
Offline Rhodemont
  • LT35HD JD4720 Norse 350 Stihl 362
« Reply #28 on: February 09, 2018, 11:07:11 AM »
Used to get it all the time.  Now I use Technu whenever I am even near the ivy and have pretty much stopped getting it.  Also, each winter on one of those real cold days I get bundled up and go out with a machete for couple hours to chop anything I find at the base of trees.  Used to have the big hairy vines in many areas and now only new trying to get started. Wash the machete with bleach before hang up for next year.  During the summer I take a walk around the perimeter of the yard, fields and paddocks to spray anything I see with round up.
Offline Brad_bb
    • My timberframe blog
« Reply #29 on: February 09, 2018, 01:46:55 PM »
Jeff is coming within a hair of the woodshed! :D
I have all kinds of poison ivy on my property.  Regular weed killer from garden sprayer will kill it.  We're not on a quest to wipe it out, just from areas we frequent- edges of the woods, trails etc.  I assumed I wasn't allergic to it, but 3 years ago while doing firewood with ivy under my feet, reaching down and picking up chunks to go in the splitter, I got it.  On my forearms that itched like the dickens.  It spread a bit.  So I got Prednisone prescribed by the dermatologist.  When i get logs with poison ivy vines on them, which are dead at that point but still probably have oil, I use my gloves to remove the vines from the logs.  Put them somewhere out of the way to decompose or landfill.  I got a few itchy bumps last summer, but not sure if it was a little ivy or not.  Wasn't bad, so I just let it run it's course whatever it was.  Since i got it the first time I keep a bottle of that poison ivy liquid soap in my truck and if I think I've touched some, I use that stuff.
Offline jmouton
  • never enough time
    • Log-Gistics
« Reply #30 on: February 09, 2018, 05:34:00 PM »
you guy s talking about poisen ivy ,,i think i  just got it,,,  i can look at it and catch it ,,i hate it
lt-25 woodmizer,25 hp kohler,hyd loading,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline ely
« Reply #31 on: February 11, 2018, 08:58:55 AM »
I never got it as a kid. Since I was 23 it tries to cover me up...we get an oral solution from a pharmacy in Shawnee ok la. That is made from the oil I think. It really helps me to not get it these days. I used to drink a tea made from green sycamore bark that helped to dry up the rash.
Poison ivy ???
Started by Camp Run Farm on General Board
Last post September 20, 2005, 08:52:44 AM
by Camp Run Farm
Is this poison ivy?
Started by Brad_bb on Sawmills and Milling
Last post April 25, 2015, 04:34:31 PM
by Magicman
Poison Ivy or Oak
Started by RichlandSawyer on General Board
Last post June 19, 2006, 09:16:03 AM
by Frank_Pender
Poison oak ID
Started by mdvaden on Tree, Plant and Wood I.D.
Last post January 09, 2007, 06:01:54 PM
by SPIKER
