EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Poison oak & poison ivy  (Read 1279 times)
Offline starmac
Re: Poison oak & poison ivy
« Reply #20 on: February 08, 2018, 11:28:49 PM »
I do not know how common it is, but I am one of the lucky ones, I could get naked and roll around in it with no ill affects. My dad was the same way, and his sisters were highly allergic to it, as was mine.
Offline ToddsPoint
  • Stockmaker and Carver
« Reply #21 on: February 09, 2018, 05:37:43 AM »
Poison oak and poison ivy are two different species.  Oak and ivy in the west are different species than in the east so you have four different species total that are poison.  The western stuff is a lot stronger than the eastern version.  Tech-Nu works great for eastern but I've heard it's not as good for western.
There is also a product called Ivy Block.  You put it on before you go in the woods.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Offline thecfarm
« Reply #22 on: February 09, 2018, 07:47:35 AM »
Some of you guys talk about that stuff vining up the trees.  :o
I just have the poison ivy. I have some on the edge of he woods. Thank God I own the woods. I have really been trying to kill it back. We,my Father and I would only spray it,total vegation killer,every few years. I Have been right at it. If it's short and green,it gets sprayed. Short as one foot tall. I might,I said might,be gaining on it. Hard stuff to kill in the woods.
I bought back some of The Farm. There was a so called stone wall that was covered in that stuff. There was a few bushes,but it was on the edge of the road and a field trying to go back to a forest. I kept that wall barren for 3 years. If it was green,it got sprayed. It did not matter if I knew it was grass,it got sprayed. I got rid of the poison ivy and it's been at least 5 years of mowing and has not came back.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #23 on: February 09, 2018, 07:53:14 AM »
   I'm like you but I get it on me or my clothes and never know I have been in it then my wife gets it. I think it would be easier to live with if I just got it, :(
Offline Southside logger
  • Sawing so I can afford to farm.
« Reply #24 on: February 09, 2018, 08:09:02 AM »
cfarm -
Around here you will find vines large enough that you could put the main trunk on your saw and cut it, the vines will go up 30' and branch out 20' to the sides hanging clusters of berries that look like small grapes - and I am not exaggerating.
'92 Franklin 170 grapple skidder
'92 Franklin 5000 wheeled buncher
Wicked Awesome Basset Hound * 2
JD 490D with 4 roller FabTek processer / hydraulic hose breaker
Hot wife
Wood Mizer LT35HDG25, Re-saw attachment
Official Member of the BBFC
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #25 on: February 09, 2018, 08:23:16 AM »
I sawed some ash logs which were covered with poison ivy.  Customer got it from head to toe, his wife was telling me about it, too much information.  :-X :-X
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline florida
« Reply #26 on: February 09, 2018, 09:22:41 AM »
Poison oak and ivy are among the easiest vines to kill. I usually use Brush Killer mixed with water. In a week the leaves are gone at which point I cut the vines with a machete then leave them alone. In a year they rot and fall out of the trees.
The rash is caused by the sap which is called urushiol.  Urushiol is actually used in Japan as a wood finish.  It does not come off with water or bleach anymore than pine sap does. It does come off with turpentine, mineral spirits or if you're in a hard spot use gasoline. Tecnu is nothing more than creamy mineral spirits.
I am as allergic as anyone and encounter poison ivy frequently. I don't go out of my way to let it touch me but wipe my arms with mineral spirits at lunch and the end of the day.
General contractor and carpenter for 50 years.
Offline Sixacresand
  • John and Nancy
« Reply #27 on: February 09, 2018, 09:54:51 AM »
I've ate it but it makes my butt itch.  :D :D :D
You probably said that as a joke.
Offline Rhodemont
  • LT35HD JD4720 Norse 350 Stihl 362
« Reply #28 on: February 09, 2018, 11:07:11 AM »
Used to get it all the time.  Now I use Technu whenever I am even near the ivy and have pretty much stopped getting it.  Also, each winter on one of those real cold days I get bundled up and go out with a machete for couple hours to chop anything I find at the base of trees.  Used to have the big hairy vines in many areas and now only new trying to get started. Wash the machete with bleach before hang up for next year.  During the summer I take a walk around the perimeter of the yard, fields and paddocks to spray anything I see with round up.
Offline Brad_bb
    • My timberframe blog
« Reply #29 on: February 09, 2018, 01:46:55 PM »
Jeff is coming within a hair of the woodshed! :D
I have all kinds of poison ivy on my property.  Regular weed killer from garden sprayer will kill it.  We're not on a quest to wipe it out, just from areas we frequent- edges of the woods, trails etc.  I assumed I wasn't allergic to it, but 3 years ago while doing firewood with ivy under my feet, reaching down and picking up chunks to go in the splitter, I got it.  On my forearms that itched like the dickens.  It spread a bit.  So I got Prednisone prescribed by the dermatologist.  When i get logs with poison ivy vines on them, which are dead at that point but still probably have oil, I use my gloves to remove the vines from the logs.  Put them somewhere out of the way to decompose or landfill.  I got a few itchy bumps last summer, but not sure if it was a little ivy or not.  Wasn't bad, so I just let it run it's course whatever it was.  Since i got it the first time I keep a bottle of that poison ivy liquid soap in my truck and if I think I've touched some, I use that stuff.
Offline jmouton
  • never enough time
    • Log-Gistics
« Reply #30 on: February 09, 2018, 05:34:00 PM »
you guy s talking about poisen ivy ,,i think i  just got it,,,  i can look at it and catch it ,,i hate it
lt-25 woodmizer,25 hp kohler,hyd loading,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline ely
« Reply #31 on: February 11, 2018, 08:58:55 AM »
I never got it as a kid. Since I was 23 it tries to cover me up...we get an oral solution from a pharmacy in Shawnee ok la. That is made from the oil I think. It really helps me to not get it these days. I used to drink a tea made from green sycamore bark that helped to dry up the rash.
Poison ivy ???
Started by Camp Run Farm on General Board
Last post September 20, 2005, 08:52:44 AM
by Camp Run Farm
Is this poison ivy?
Started by Brad_bb on Sawmills and Milling
Last post April 25, 2015, 04:34:31 PM
by Magicman
Poison Ivy or Oak
Started by RichlandSawyer on General Board
Last post June 19, 2006, 09:16:03 AM
by Frank_Pender
Poison oak ID
Started by mdvaden on Tree, Plant and Wood I.D.
Last post January 09, 2007, 06:01:54 PM
