Author Topic: Charging a premium  (Read 3481 times)
Offline PAmizerman
  • Just Another Day In Paradise!!
Charging a premium
« on: February 08, 2018, 10:30:23 AM »
So I just took three orders this week. They all want 1x10 for siding with 1x3 battons. I've been charging the same price per board foot no matter the width. I'm still sitting on over 2000 feet of 1x8 from last year that was side lumber from a 1x10 job. Nobody wants them. I was thinking about raising the price per foot on my 1x10 and even more for 1x12. Does anyone else charge a premium for the wider boards? It's all hemlock. If you raised you're price did you notice any difference? Or do people want what they want and still pay for it. I just don't want to lose any work over a price increase.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline alanh
Re: Charging a premium
« Reply #1 on: February 08, 2018, 11:02:37 AM »
I`m not sure about charging a premium but  if I had that many 8`s left I`d be thinking about cutting all those battons from them..talk them down to 2", no waste?
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: February 08, 2018, 12:05:59 PM »
   I see nothing wrong with charging a premium for special orders. The basic question I think you should ask yourself is:
   Is it going to cost me more to cut this wood? Will I have to pay more to get the logs? Will it take me longer to cut it? Do I have to have more help or equipment to cut this order? Do I have a market for any side lumber resulting?
   If the answer to any of the above questions is yes you need to calculate your extra costs and pass them along to the customer.
   BTW - If you are having a hard time getting rid of the 1X8's you might offer to change the batten size to 2" (if the customer can use that) and sell them at a discount. Could you cut them into 2-3" battens and get a 2" furring strip or 2-1" tomato stakes that you could sell to other customers or do you need any stacking strips from the 1" residue?
   When cutting 3" battens I find there is just about no waste off the log.
Offline Mt406
« Reply #3 on: February 08, 2018, 12:46:08 PM »
I have found I have to charge a premium. Case in point. The job I am working on now is 156 3 x 12 x16. I've had to dig a part 2 log decks a total of 3 logging trucks of wood to get logs and had to buy two more logging trucks of wood at a premium price. Normal price here is 85 a ton for these two loads I'm paying 120 a ton. As a result my log yard looks like Pick-up sticks from sorting wood and trying to keep them out of the mud which will take me more time to clean before I Mill so a premium is a must for me anyway. And as for cutting smaller one by threes or one by fours I no longer do that because of the time and waste my opinion would be to sell him the one by Eights at a reasonable price and let him rip them himself and install. That's just my two cents.
Scott
Offline moodnacreek
  • Sawin by the notches
« Reply #4 on: February 08, 2018, 01:07:45 PM »
Each territory has it's own conditions. In my case 2x white oak or locust is the thing. Side boards; 1x6 8' and 16' no problem but 10,12 and 14' no can sell. I burn all the edger sticks and half the slabs and have to give away the saw dust. A little farther up state they can sell all the saw dust and if there is a pallet operation near by all the side lumber and maybe the slabs. So I charge all I can get for what is in constant demand or I can close. Don't bad mouth the other guy for charging more unless you completely understand that area.
« Reply #5 on: February 08, 2018, 01:09:50 PM »
Scott and Moody,
   You guys make a real good point here about the 1X3 & 1X4's for you and what sells and does not for him. You have found they are not cost effective for you to cut and don't waste your time. Anyone staying in business needs to know what is profitable and what is not for his situation.
   My milling is largely a paying hobby - I expect to recover my costs plus some but it is not how I make my living so I can afford to cut some items others can't. My lumber sales are from trees I am salvaging off my place that would otherwise go to waste that i cut when I do not have a mobile sawing job to do.
    My suggestions on the 1X8s were just a proposal to get rid of some lumber PAMizernan said had that he said he was having trouble getting rid of. Actually, 1X8's are pretty popular here and I'm surprised they are slow movers but there are different markets in different areas. I can promise as soon as he gets rid of them someone else will come along wanting all he had had plus more. ;D
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #6 on: February 08, 2018, 06:07:44 PM »
I would hang on to the 1x8's. They will sell come spring. Be patient.
Incidentally I've never like a 2 inch baton.  ;D
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #7 on: February 08, 2018, 06:17:08 PM »
My 6" wide pine will pile up some. It will move just slow. Someone will come in and buy all of it.
The whole thing is to keep the lumber in good shape to sell.
A&P saw Mill LLC.
License NH softwood grader.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #8 on: February 08, 2018, 06:27:39 PM »
I don't care for 2" battons, and usually saw out 3", so I would maybe suggest sawing the 8" boards into 2.6" battons, roughly 2½", so 3 battons per 8" board!
~Chuck~
I LOVE MY SAWMILL
Offline PAmizerman
« Reply #9 on: February 08, 2018, 06:46:54 PM »
Well I worded that kind of poorly. I guess my question is do you have different price points for lumber based on width and how much of a headache does it cause you. Right now I only have two price points...dry and green.
Thanks for all the input so far. I really don't have an issue with the 1x3 battons. I take all the side 1x6 and 1x9 and saw them into battons. It usually works out pretty close for me. So all I have left is the 1x8.
I would not be too overly concerned about the Inventory but I'm pretty limited on space where I'm at now.
I was just wondering if price points might help me move lumber a little more consistently.
As far as cutting them into battons I just have a gut feeling as Soon as I do someone will show up and want them. And I really don't have to cause like I said I cut all my 1x6 into battens with zero waste.
WM bms250 sharpener
WM bmt250 setter
Offline carykong
  • Installing my roof ridge metal
    • Have Mill Will Travel
« Reply #10 on: February 09, 2018, 10:26:54 PM »
Most of my work is incidental and most of the jobs are under 1000bdft.  I have learned the hard way that you can get buried in unsold side lumber.  Because I am real small, I encourage my customers to buy my lumber by the log now.  They pick out the log and I sell them the log sawed at doyle scale  and all the primary and side lumber is theirs.  Keeps my pasture clear.
    • A&P Saw mill LLC
« Reply #11 on: February 09, 2018, 10:38:04 PM »
Not a bad idea carykong.
A&P saw Mill LLC.
Offline redprospector
« Reply #12 on: February 09, 2018, 11:43:22 PM »
I have a price break at 10” wide. I also have another price break at 20’ long, and then again at 24’, 26’, 28’, and 30’.
I’ve found that people are willing to use shorter narrower material if the wide long stuff costs more. They also still buy the wide and long stuff when they need it.
Offline highleadtimber16
  • Learning Everyday
« Reply #13 on: February 09, 2018, 11:51:44 PM »
Side lumber has always been an issue it seems. I've found the best way to deal with it, is to keep it clean, organized, and well presented. I have a 12'x20' shed that all my 1" and 2" lumber goes in. It gets pretty full in the winter, come spring it's mostly all gone, and I'm scrambling to keep it stocked. I charge the same price per/bdft whether it's a 1x4 or 1x12. If it is an odd size or something over 12", the price goes up. Sometimes I'll bundle up a lift of utility and put it on craigslist, it goes pretty quick.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline PA_Walnut
« Reply #14 on: February 10, 2018, 06:09:32 AM »
Not to derail the topic, but I'm about to saw a lot of board and baton for my own use. What size should I aim for on each?
Have plenty of logs to make what I want, but would like to handle it least as possible!
Thx
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Online Ron Wenrich
« Reply #15 on: February 10, 2018, 06:31:57 AM »
I have board and batten on my house.  Its an 1850s farmhouse.  I used random width boards and a 2½" batten.  That is what was originally on the house.  I used mainly 10" and wider for the boards.  Very little waste.  3" was used on the corners.
Offline thecfarm
« Reply #16 on: February 10, 2018, 06:37:22 AM »
I saw a building with 4 inch batten and 10 inch. I drove by that for months before finally I saw someone out. I could not really tell the size of what he used,until he told me just driving by. All I knew was,I liked the looks of it.
Offline longtime lurker
« Reply #17 on: February 10, 2018, 07:04:10 AM »
Looks like Hansel and Gretel should be coming out the door Ron, like something from a storybook. Pretty.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #18 on: February 10, 2018, 01:00:50 PM »
I've been sawing out some white pine timbers for the last two months and making lots of side lumber. Saving 6" up to 12" all lengths. I have a customer who said he'd buy a lot of it for his 57' timber frame barn he's going to build for his sail boat.
He gave me a list of what he wanted first, so many feet at 8' length, so many feet at 10' lengths, so many feet 12' lengths. These feet are the distance down the side of the garage extension he's building between the house and the barn. It was easy to fill the 8' lengths order. The 12' lengths I just finished. Now he needs 30' of 10' long stock.
After the first delivery of 6", 8", 10" and 12" (mostly 8' long) stock he told me nothing smaller then 10". Which really sucks as three 8" piece make up two feet.
I'm stacking the 6's and 8's aside now, and trying not to make many.
I quoted him one price last fall. And I went up Dec 1st on all prices for everything.
I hadn't raised my prices since 2013 or so.
I hope I will be able to sell off these narrower boards some time.
I have considered upping the price due to the limit of 10" & 12" but I'll wait till he complains about some lumber.
He told me he only wanted lumber without any bug holes and some of these logs have been here a while. and have some blue stain and small bug holes.
And he doesn't want any "gray" lumber only fresh cut so it will all "weather" the same.
I had a farmer come in and he wanted 400 bdft of 10" and 12" stock and he said he didn't care about blue stain or small bug holes. I set aside 460 bdft for him. He has taken 200' bdft so far and said he'd be back soon for the rest.  So I am moving some of the lumber out.
Jim Rogers
Offline brianJ
  • Only get excersize if I choose the right hobby
« Reply #19 on: February 10, 2018, 03:34:49 PM »
Should I charge a premium?    Well I infer you have less of the wide 10 and 12 inch boards than medium or narrow boards and I infer people want the wider boards more than the medium or narrow boards.   Simple supply and demand.   Seems only logical to charge more.  I dont understand why you would tie yourself in knots trying to justify a higher price.
Perhaps a more precise question is,  "How much of a premium are the wide boards worth? and possibly at which size do you start charging a premium.
Premium
Started by woodmills1 on Sawmills and Milling
Last post March 03, 2006, 08:40:44 AM
by woodmills1
Does anyone charge a premium ?
Started by Paddlefish1406 on Sawmills and Milling
Last post September 18, 2017, 05:04:47 PM
by Tim
thumbup
Scored my premium domain name today.
Started by DR_Buck on General Board
Last post July 01, 2018, 06:52:08 AM
by Cedarman
Premium 92 octane non ethenol fuel
Started by HuckFin on Chainsaws
Last post September 23, 2014, 01:32:33 PM
by ZeroJunk
